Spitfire Electric brake switch issue
Jerry
Group,
Helping a friend with a 75 Spitfire. He has an electric brake switch on the pedal. The original is gone, ie; no switch and no nut to hold it on.
The replacement: https://www.rimmerbros.co.uk/Item--i-134529
This is plastic and has threads to go into a nut of some kind. I cannot figure out what thread it is. I have tried metric and UNF but they don't fit. Any ideas?
Jerry
dklawson
From memory I thought the threads were 1/2-20. Being plastic, you may find it difficult to get a metal nut to thread easily on the switch.
For future reference, the switches are much less expensive at BP Northwest than Rimmer or the other sources.
BP Northwest Link
An alternative you may want to pursue is the "generic" AirTex brake switch for an early 1970s BMW 2002. They are affordable through RockAuto. They are metric but will fit and come with the jam nuts.
RockAuto Link to BMW Switch
J
Jerry
thanks Doug, I have directed him to BPN many times but he keeps going back to Rimmer. Some of the parts he needs are for a right hand drive car so he gets fixed on buying from Rimmer.
You are correct about the metal nut on plastic. The nut tightens and the switch falls apart before seating.
Tony P
Member
Hey guys, I went to ROCKAUTO and found a very nice brass and plastic switch from a 1980 BMW. Now i can get rid of the sub par plastic junk I got from both Rimmer and BPN.
Thanks again
Tony P
Geo Hahn
FYI - I have used this one to add a mechanical switch to an originally hydraulic switch system. Has been reliable:
https://www.amazon.com/gp/product/B...rue&ref_=ox_sc_sfl_title_9&smid=ATVPDKIKX0DER
dklawson
Tony and Geo, the switches I mentioned back in June were BMW parts. The Amazon switch Geo linked to is the same switch I bought from RockAuto. It is probably cheaper through Amazon once you factor in shipping.
AndreL TR6 Conversion to electric fuel pump Triumph 11
Guido36 Electric Power Steering Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
DrEntropy Benz electric window battle Other Cars 13
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
J Electric Ready? Electric Upgrades of All Sizes 3
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
Gliderman8 Electric classic cars Electric Upgrades of All Sizes 22
B Intermittent Loss of Electric Power Austin Healey 18
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
R Electric fuel pump wiring Spridgets 4
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
R Rewind electric motor Restoration & Tools 3
JPSmit Electric Midget Spridgets 1
M TR6 Electric Powered Rack & Pinion. Triumph 4
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
D Spitfire Electric fan Triumph 3
B TR4/4A Mechanical fuel pump vs electric Triumph 16
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
K TR2/3/3A An Electric TR3 ?? Triumph 3
Lin Electric Relay Placement Austin Healey 11
nevets interesting article about converting classic cars to electric power Austin Healey 7
FlyingCat Spitfire Electric Radiator Fan Triumph 10
M The electric E Jaguar 1
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N Electric fan opinions???? Spridgets 2
P electric clutch Austin Healey 1
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
Geo Hahn General Tech Emergency Electric Fuel Pump Triumph 29
B Electric fan Austin Healey 2
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
rjc157 TR6 Electric fan Triumph 5
johnrip Wedge tr7 electric fuel pump Triumph 2
exfed12825 General Tech Electric Power Steering With Fail Safe MG 0
Jer is it posible to fit an electric temperature gauge ? Spridgets 4
Got_All_4 General TR Electric fuel pump for in my possibles bag Triumph 12
Michael Oritt Electric tachometer connections--No Healey content Austin Healey 7
M TR2/3/3A Electric Fuel Pump Installation Triumph 12
J TR2/3/3A Radiator removal ?? electric fan vs original Triumph 7
T ?Changing BE to SU electric fuel pump Spridgets 8
S TR4/4A electric fan Triumph 6
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
KVH TR4/4A Electric Overdrive Lever Switch Triumph 3
mgedit TR2/3/3A Electric Powered TR3 Triumph 8
O Electric choke problem. Jaguar 0
