General TR Electric fuel pump for in my possibles bag
Got_All_4
Putting together a "possibles bag" a bag that will consist of some tools and other small parts like points, fuses, wire, extra sparking plugs and a electric fuel pump to get me home. My question is for my TR3's bag. It has of course 2 stock SUs and I'm looking for the proper PSI for the electric fuel pump to purchase. Possibly a Facet or Facet re-pop. 1.5 to 4 PSI just right or 2.0 to 4 PSI too high? Also eventually I'll need one for my TR6 too but assuming I could use the same size pump.
I'm not planning to not permanently mount it but with some quick connectors and some short hoses and clamps I cam make it work.
M_Pied_Lourd
I carry the same for my emergency roadside fixes (if required). I purchased A facet cube kit, part number FEP-42SV. It came with a fuel filter and nuts and bolts to mount it for 48.99. I bought it from a company called Aircraft Spruce up here. It is a 1.5-4 psi min/max pump. And yes, I use it for both my TR3A and TR6 running stock carbs.
Cheers
Tush
Gliderman8
I've been using the same Facet pump Tush is using. It's been in my TR6 for at least two years with no problems at all. It does make a "clicking" noise every so often but I think that's normal for Facets.
Got_All_4
Got_All_4
Sounds like were on the same page. I had to learn the hard way last summer I was at the TRF Summer Party when my mechanical fuel pump went out and a friend had this neat tool kit with a Facet pump he carries for a spare and let me borrow it to get back to the Factory to buy a new pump. Surprisingly it pulled the fuel right through the mechanical pump. Putting one together for all the TRs. This will be riding in the bag until called upon.
Sarastro
I think that Facet pump is a good choice. I had one in my Bugeye Sprite and I put one in my Porsche, too. Actually, in the Porsche, I used the one with the next higher pressure range and regulate it down to 2.5 PSI with a Holley regulator. It works just fine.
With SU carbs, you don't want more than about 3 PSI. It might be a good idea to hook up the pump and see what its back-off pressure is. If it's too high, it can push fuel past the float valve. That's why I used a higher pressure and regulator on the Porsche. I'm planning to use the same setup on my TR4A too.
dklawson
As part of survival kits, I have Facets in the boot of the Mini and my wife's GT6. I soldered on some extension wires and terminated those with alligator clips. In the bag with the pump I included decent lengths of 1/4" fuel line and assorted hose clamps. Since putting the kits in the two cars I have not had to use them. Prior to making the kits I did have to bottle feed the Mini to get it back up the driveway when its pump failed moments from leaving the house. It's good to have a spare while on the road.
Got_All_4
Got_All_4
Ok now I'm down to ether a Facet or EMPI pump to purchase. That latter is more reasonably priced and a good name too. However I can't seem to find out if it cuts off fuel if it senses too much back pressure. I am assuming that Facets pumps do?
charleyf
Okay, I will ask an obvious question. If you are wanting to carry an extra fuel pump. What is wrong with carrying a stock fuel pump. I know that the rear nut on the fuel pump is difficult to get to. But I have figured out that a `1/4" drive socket with a short ( about 2-3") wobble extension works good for that one. I carry a stock fuel pump and a water pump with a pulley mounted.
Charley
TFB
Charley
One advantage of the electric back up besides the easier plug in and connect is that a spare electric with a short length of hose is also a good transfer pump for an out of gas situation.
Tom
M_Pied_Lourd
I actually carry a mechanical pump as well for both the TR3A and the TR6. Changing the pump on a TR6 is a piece of cake compared to a TR3A. I can do a roadside swap of a TR6 on a hot engine in about 20 minutes on a 6...on a 3A there is less space and more difficult access to the nuts holding the pump on plus that **** oil line....if I broke down roadside on the 3A, I would get to where I was going and then switch out the pump when the engine was cool and you are under less pressure to get the car going...
My 2 cents.
Cheers
Tush
dklawson
In the case of our GT6, the stock mechanical pump was gone by the 1970s when my father-in-law removed it. Carrying the spare electric pump for us is carrying a like-for-like replacement.
If you are just carrying the extra pump for emergency use, there are several others that will work (Mr. Gasket, Carter, and Airtex among others).
EDIT: For a list of alternates see the MGA Guru website. Link below.
https://mgaguru.com/mgtech/fuel/fp201.htm
PatGalvin
Hey Guys:
Can one of you explain how you would (or do) hook up the Facet pump when doing emergency roadside repairs, due to failed mechanical pump? I'm not really clear how this would work and would like to understand the details of this temp install. I assume you'd hook up the pump to the battery with long leads and some some spring clamps. Where would you mount the pump?
Thanks for any wisdom you all can share.
Pat
Got_All_4
Got_All_4
This is going to be a back up pump to get me where I need to go or to a safe place to do a swap if I have a new one. However I usually don't carry one. This electric pump is to help save space and piece of mind. Installation was easy. Pulled off the rubber hose on the pressure side of the manual pump. Slipped on a rubber hose from the outlet of the stock pump to barbed fitting on the inlet side of the e pump. Then plugged in the other side of the e pump that had a barbed fitting into the rubber hose connector on the pipe to the carb. Took one of the bolts out from the coil mount and attached the ground wire to that and the hot wire went to the coil. The e pump was able to draw the fuel through the broken stock pump. This was on my TR250.
AndreL TR6 Conversion to electric fuel pump Triumph 10
Martinld123 Electric Fuel Pump Austin Healey 6
R Electric fuel pump wiring Spridgets 4
B TR4/4A Mechanical fuel pump vs electric Triumph 16
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
Geo Hahn General Tech Emergency Electric Fuel Pump Triumph 29
johnrip Wedge tr7 electric fuel pump Triumph 2
M TR2/3/3A Electric Fuel Pump Installation Triumph 12
T ?Changing BE to SU electric fuel pump Spridgets 8
T TR2/3/3A Location for electric fuel pump? Triumph 21
tinman58 TR2/3/3A Electric fuel pump questions. Triumph 5
Coyote1 General Tech Is there a quiet electric fuel pump Triumph 11
Gliderman8 TR6 Mounting location for electric fuel pump on TR6 Triumph 42
Gliderman8 More electric fuel pump questions... Triumph 6
Gliderman8 Electric fuel pump install help... please Triumph 24
L Best electric fuel pump for Weber DGV carb Spridgets 10
L Electric fuel pump for Weber DGV carb Austin Healey 3
bigjones Installing electric fuel pump Spridgets 34
M electric fuel pump power supply? Triumph 14
tban52 Electric fuel pump Triumph 5
wangdango TR6 76 TR6 electric fuel pump? Triumph 3
pjsmetana Electric Fuel Pump or carry a spare Mechanical? Triumph 15
RedTR3 TR2/3/3A TR3 Fuel Pump: Mechanical vs. Electric Triumph 14
jaegzie hooking up electric fuel pump Spridgets 7
veale001 Mechanical or Electric Fuel pump? Triumph 15
drooartz Running fuel lines/electric pump Spridgets 20
M_Pied_Lourd Old Electric Fuel Pump Question Triumph 15
Gliderman8 TR6 TR6 Fuel electric pump? Triumph 14
tosoutherncars Weber DGV, cont'd... Electric fuel pump install Spridgets 19
sparkydave Electric fuel pump question Spridgets 13
T Electric fuel pump question Triumph 29
emann Electric Fuel Pump Spridgets 6
bluemiata90 electric fuel pump....rear or engine compartment Triumph 7
J Power for electric fuel pump Spridgets 4
B BE Electric Fuel Pump Q Spridgets 22
D TR4/4A Electric Fuel Pump for TR4 Triumph 5
P Electric Fuel Pump for Bugeye??? Spridgets 12
S Electric Fuel Pump vs. Mechanical Pump Triumph 18
B Electric fuel pump for a bugeye - Questions. Spridgets 13
roofman Facet electric fuel pump - need advice Triumph 15
hondo402000 electric fuel pump installation Triumph 5
P TR4/4A TR4A Electric Fuel Pump Installation Triumph 7
K more electric fuel pump ?s MG 8
T Electric vs Mechanical fuel pump? Triumph 3
T AC Electric fuel pumps - time for some schooling.. Triumph 10
L Electric fuel pumps Lotus 10
J electric fuel pumps Austin Healey 9
Guido36 Electric Power Steering Austin Healey 2
DrEntropy Benz electric window battle Other Cars 13
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
