More electric fuel pump questions...
Gliderman8
OK, I seem to have all the components to hookup the electric fuel pump except one.....
Once I remove the mechanical pump, how do I connect the 5/16" hose coming from the electric fuel pump to the metal line that was screwed into the old mechanical pump which goes to the carbs?
Do I just slide the compression nut back and push the hose over the flared end of the metal pipe and use a hose clamp?
Seems like a silly question, but I could use an answer. Pics of your hookup would be good too!
Thanks for any help you can offer.
DanB
Have you mounted your electric fuel pump in the engine compartment? Mine is in the rear wheelwell near the tank.
There are several ways you could hook it up. You could cut the flare off and remove the nut so it isn't rattling around and just put a hose and a clamp on there. That would probably be the simplest. Or you could find a hose barb that would screw on to you fitting. I don't know what the threads are, maybe someone else does....
Dan B
Gliderman8
Gliderman8
Thanks for your reply dan...
I intend to keep the mechanical pump in the boot as a spare; with that said, I do not want to cut the threaded connection to the pump off in case I need to re-install it on the road.
As for finding a hose barb with a threaded female end and a 5/16" hose barb that would be ideal, but I've yet to find one!
Does anyone know if such a like this exists?
I haven't mounted the pump yet... I would like to mount it so I have access to it when required. Somewhere low on the fire wall or nearby chassis might be a possibility.
DanB
https://www.mcmaster.com/#push-on-hose-fittings/=jyo5vm
You might be able to find the hose barb locally, or at McMaster Carr at this link.
How about mounting it to the blanking plate on the engine block? Then if you need to swap it out with the mechanical one you could just take it off and throw it in the trunk, and the lines should be pretty close to where they need to be.
TR3driver
Great Pumpkin - R.I.P
IIRC, the TR6 pump outlet fitting is the same as TR2-4 (even though the pump is different). If so, that is a special "inverted" compression fitting used only for fuel. You are not likely to find a mating adapter at MMC or any other general purpose supply house.
The easy route IMO would be to cut the existing line, then keep the cut end (with nut), a short length of suitable soft line, and a pair of hose clamps along with your spare mechanical pump.
Or just carry a spare electrical pump, which would be a lot easier to press into service on the side of the road.
Gliderman8
Gliderman8
Thanks Randall... that is not a bad suggestion (cutting the existing line). First I will give it a go to see if I can find the proper fitting; if not, then I think your "plan B" works just as well.
K more electric fuel pump ?s MG 8
Bayless More Prefect Progress Other British Cars 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB More Weber help needed MG 27
DrEntropy More lessons in Japanese engineering Other Cars 7
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
Bob Claffie More Village pics Other British Cars 0
Bob Claffie More Village pics Other Cars 3
M TR6 More noob questions… Triumph 14
Bayless More Paint Other British Cars 3
AngliaGT A Few More Local Vehicles Spotted 5
Basil More BMW Z4 trials Other Cars 21
AngliaGT A Few More I saw Yesterday Spotted 10
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
D TR2/3/3A More Fuel pump questions. Triumph 10
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
7 No more Bosch tools for me Restoration & Tools 4
D TR2/3/3A More small nuts [ and studs!] Triumph 2
C TR6 More fun with Lucas Triumph 5
Bayless More Sprite progress finally Spridgets 23
Bayless Even more progress - the Prefect Other British Cars 5
maxwedge5281 one more time.....mirrors! Austin Healey 14
Bob Claffie T-Series More or less TD action MG 0
R More Shroud to Scuttle install Austin Healey 4
Y MGB Answer to a question creates more new questions.... MG 12
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
S TR2/3/3A little more door gap Triumph 14
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
D BT-7 tri-carb Two more questions Austin Healey 18
R TR2/3/3A One more crank pulley question Triumph 7
