TR2/3/3A Rack and pinion TR3
fad64b
To rack and pinion, or not to rack and pinion a TR3 has been discussed many times on this board. It is not my intent to reopen this subject, what I wanted to do is make other TR3 owners aware that a rack and pinion conversion can be done with out spending $1500.00 on a kit. I just completed converting my TR3 for under $350.00, and would like to share what I have learned. To start here is a list of parts I used.
Upper half of a TR3 steering shaft (my car had a one piece steering column)
TR7 steering rack
TR7 lower steering shaft with both universal joints
Spitfire tie rods
Spitfire Tie rod ends
Electric fan
Steel to fabricate bolt in brackets
Also if the fan extension is cut with a hack saw across the face where the bolts attach the pulley, then grade 8 bolt and washer can be used to reattach to the crank making room for the rack and electric fan.
Provided you take your time and can weld you can save money without sacrificing quality
startech47
Can you post drawings for the brackets? Did you check the bump steer? I'm ready to start cutting parts out and welding.
martx-5
How did you handle the horn and directional wiring??
TR3driver
Great Pumpkin - R.I.P
So how did you check that the Ackerman angle is correct ?
fad64b
fad64b
Art, Have not worked out the wiring yet. I thought I could work it out using the original control head. The problem is now it will follow the steering wheel so it will not cancel. I am working on pictures and drawings, the brackets start with square tubing (2 3/8 outside X 3 1/2 tall)that fits in the frame where the steering box bracket mounts and idler bracket on the other side. My brackets look similar to the ones in the kits sold on ebay and sold on this site.
https://www.trparts.com/newitems/tr3guide.html
I tried to get the rack as low as I could with out interfering with lower wishbone. I read somewhere about using TR6 lever arms and reversing right to left and so on. This would raise the position of the tie rod end, but you would have to then use TR6 tie rod ends. You would understand what I mean if you could compare a TR3 steering Lever and a TR6 lever. I wished I was as good as Tinster at taking pictures and documenting my projects.
Geo Hahn
fad64b said:
...Have not worked out the wiring yet. I thought I could work it out using the original control head...
Bob Schaller's "More BS..." addressed one solution for this. Here is a pic of the gadget he used to keep the horn button. Trafficators are another matter.
martx-5
British Parts Northwest has a kit that they claim allows you to retain the original steering wheel controls. By looking at the picture of the parts, it looks like that top piece with the serrations on the top and the nubbies on the side is the magic piece. Perhaps this part (and any other associated parts) are available seperately.
fad64b
fad64b
Art,
Would be great if a source could be found I think your on to something. That beats reinventing the wheel, what I was think is a three conductor coiled cable that I could fasten to the wires in the upper shaft loosely wrap on the upper shaft so when truing in one direction it would have room to tighten and turning in the other it would unwrap.
martx-5 TR2/3/3A Last Hurdle w/TR3 Rack & Pinion Triumph 5
prb51 TR2/3/3A German TR3 Rack & Pinion kit Triumph 10
C TR2/3/3A TR3 Rack and pinion conversion Triumph 6
prb51 TR2/3/3A Ebay TR3 with rack?pinion and fan unit Triumph 1
A TR2/3/3A rack & pinion steering for a TR3 Triumph 5
bluemiata90 TR2/3/3A TR3 rack and pinion conversion /turn signals Triumph 9
J TR2/3/3A Rack and Pinion for a TR3 Triumph 19
bluemiata90 TR2/3/3A Mustang II rack and pinion conversion to TR3 Triumph 5
Russ Austin TR2/3/3A TR3 Rack and Pinion Triumph 6
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
M MGA RHD rack and pinion wanted MG 19
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
C TR2/3/3A Rack and Pinion Conversion for Tr's Triumph 0
M TR6 Power Steering Rack & Pinion. Triumph 3
M TR6 Electric Powered Rack & Pinion. Triumph 4
T XK120 fit 140 rack & pinion Jaguar 3
M TR2/3/3A Identification of Rack and Pinion Unit Triumph 3
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
K TR2/3/3A DIY TR3A Rack and Pinion Steering Conversion Triumph 0
BoyRacer Rack & Pinion steering for 3000 Austin Healey 12
J TR2/3/3A Rack & Pinion warning on TR3s-- Triumph 10
TRMark TR4/4A Play in steering pinion & rack mount mod Triumph 3
J Brittanicar Rack and Pinion Conversion Austin Healey 10
S Anyone need a rack and pinion for a project? Other Cars 1
F Spitfire Spitfire rack n pinion lub Triumph 6
B TR4/4A TR4 to TR3A Rack & Pinion swap Triumph 4
smaceng Steering Rack Pinion Leak Spridgets 11
T T-Series Need advice re MGTF rack and pinion removal MG 4
60TR3A TR2/3/3A TR3A Conversion to Rack-&-Pinion Steering Triumph 33
Jim_Stevens Rack and Pinion Conversion- lessons learned Triumph 5
Lin Rack and Pinion Jaguar 3
B E Type rack and pinion motion Jaguar 4
P Panther Kallista, rack and pinion woes... Other British Cars 5
L Rack and pinion for big Healey? Austin Healey 9
1 rack and pinion Spridgets 2
gubba Has anyone here used this Rack & Pinion? Triumph 8
T TR2/3/3A 1960 TR3A now with rack and pinion Triumph 22
T TR2/3/3A Best place to buy a rack and pinion for TR3A? Triumph 13
C TR2/3/3A TR3A Rack and Pinion and Alternator in!! Triumph 9
T Rack and pinion, oil or grease? Triumph 6
77_MG_Midget Rack & Pinion Steering question, 1500 midget Spridgets 2
R Rack & Pinion Conversion Healey 3000 1964 Austin Healey 11
bluemiata90 TR2/3/3A TR3A rack and pinion conversion-yes or no Triumph 8
philman removing nut for steering rack pinion gear Restoration & Tools 0
philman rack and pinion tool question Triumph 1
G Rack & Pinion installation MG 2
T TR6 Need a slower rack and pinion for my 69 TR6 Triumph 7
S BJ7 - Parts Needed & Rack & Pinion Inquiry Austin Healey 4
