Rack and pinion for big Healey?
Legal Bill
Not that I'm about to do this, but I was just wondering if anyone has a good conversion kit or a good paper discussing converting a big Healey to rack and pinion steering. To me, it has always seemed to be a good idea, but I have only seen one reference to such a conversion.
Cottontop
Bill,
I am wrapping up a handfull of mods on my big Healey 100-8. Among the half dozen mods is a Rack & Pinion unit.
While I really didn't look for a "kit" to install, I did consult with 6-7 big Healey owners, including a British race car builder, who had installed R&P units. I also went to a local shop that builds chassis for circle track cars.
IF anyone is planning to install a R&P unit, "Ackerman Angle" and "Bump Steer" MUST be fully understood, lest you end up with an unmanagable beast.
Tim
L
Legal Bill
Wholly smokes!!! Look at that thing. I'm not sure I would have guessed it was healey if you had just showed me a picture. Did you mount it directly to the cross member of the car?
L
Legal Bill
Thanks Greg. that is just the sort of write up I'm looking for. By the way, I think I asked this elsewhere, but what is the intake set up in your signature line?
Cottontop
Bill,
Yes and No... Yes, the R & P IS bolted to the front crossmember, but No, not directly.
The shortened R&P is actually out in front of the crossmember and oriented such that the rack ball ends are precisely ON the centerline of the lower arm pivot bolts.
The orange cups hold the bottom of the 24" wide radiator.
MY problem in putting the R&P most other places is that I have a 24" wide radiator, with 2 - 12" electric fans on the back, slanted back at a 15 degree angle. Nearly any other R&P position interfered with the fans and motors.
Here is an older top view. The engine is a 300 HP Ford 302 with a 4 speed automatic overdrive transmission.
With my distributorless ignition, that red distributor will come out and the plug wires will be fed from the back. They will never show when dressed below the valve covers.
WHY you might ask ? Here is a pic from a few years ago when I was out killing some traffic cones. Now... THAT'S FUN !
Tim
AJAX50
Modern, or more correctly current, Morgans have R+P with the off take points in the middle of the rack so easing or removing the undoubted geometry problems.
Roger
Bronze
That's true for the Morgan's sliding pillar geometry, with it's infinite virtual swing axle length, but would not be true for a wishbone setup like the Healey. It would pretty much guarantee bump steer.
B
BUNDYRUM
Hello AJAX50,
The positioning of the pinion on the rack has no bearing on the geometry issues faced when installing a rack in a Healey.
It's all to do with where you place the r & p in relation to the lower wishbone inner pivot points as pointed out by Cottontop.
Get it wrong and you're quite literally "all over the place".
Get it right and you wouldn't believe you're driving a Healey.
Best regards,
bundyrum.
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
M MGA RHD rack and pinion wanted MG 19
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
C TR2/3/3A Rack and Pinion Conversion for Tr's Triumph 0
M TR6 Power Steering Rack & Pinion. Triumph 3
M TR6 Electric Powered Rack & Pinion. Triumph 4
T XK120 fit 140 rack & pinion Jaguar 3
M TR2/3/3A Identification of Rack and Pinion Unit Triumph 3
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
K TR2/3/3A DIY TR3A Rack and Pinion Steering Conversion Triumph 0
BoyRacer Rack & Pinion steering for 3000 Austin Healey 12
J TR2/3/3A Rack & Pinion warning on TR3s-- Triumph 10
TRMark TR4/4A Play in steering pinion & rack mount mod Triumph 3
J Brittanicar Rack and Pinion Conversion Austin Healey 10
S Anyone need a rack and pinion for a project? Other Cars 1
F Spitfire Spitfire rack n pinion lub Triumph 6
B TR4/4A TR4 to TR3A Rack & Pinion swap Triumph 4
smaceng Steering Rack Pinion Leak Spridgets 11
T T-Series Need advice re MGTF rack and pinion removal MG 4
60TR3A TR2/3/3A TR3A Conversion to Rack-&-Pinion Steering Triumph 33
Jim_Stevens Rack and Pinion Conversion- lessons learned Triumph 5
Lin Rack and Pinion Jaguar 3
B E Type rack and pinion motion Jaguar 4
P Panther Kallista, rack and pinion woes... Other British Cars 5
1 rack and pinion Spridgets 2
gubba Has anyone here used this Rack & Pinion? Triumph 8
martx-5 TR2/3/3A Last Hurdle w/TR3 Rack & Pinion Triumph 5
prb51 TR2/3/3A German TR3 Rack & Pinion kit Triumph 10
fad64b TR2/3/3A Rack and pinion TR3 Triumph 8
C TR2/3/3A TR3 Rack and pinion conversion Triumph 6
prb51 TR2/3/3A Ebay TR3 with rack?pinion and fan unit Triumph 1
T TR2/3/3A 1960 TR3A now with rack and pinion Triumph 22
T TR2/3/3A Best place to buy a rack and pinion for TR3A? Triumph 13
C TR2/3/3A TR3A Rack and Pinion and Alternator in!! Triumph 9
T Rack and pinion, oil or grease? Triumph 6
77_MG_Midget Rack & Pinion Steering question, 1500 midget Spridgets 2
R Rack & Pinion Conversion Healey 3000 1964 Austin Healey 11
A TR2/3/3A rack & pinion steering for a TR3 Triumph 5
bluemiata90 TR2/3/3A TR3 rack and pinion conversion /turn signals Triumph 9
J TR2/3/3A Rack and Pinion for a TR3 Triumph 19
bluemiata90 TR2/3/3A TR3A rack and pinion conversion-yes or no Triumph 8
bluemiata90 TR2/3/3A Mustang II rack and pinion conversion to TR3 Triumph 5
philman removing nut for steering rack pinion gear Restoration & Tools 0
philman rack and pinion tool question Triumph 1
G Rack & Pinion installation MG 2
T TR6 Need a slower rack and pinion for my 69 TR6 Triumph 7
S BJ7 - Parts Needed & Rack & Pinion Inquiry Austin Healey 4
Basil Rack and Pinion? Austin Healey 4
