BJ7 - Parts Needed & Rack & Pinion Inquiry
ScottGraham
I am buying a 63 BJ7 in reasonable semi restored state. I am looking for the following:
- Rear seats and installation parts (currently a bench)
- 3 x Weber conversion
- Aluminum head
- Used hard top
- Motolita stye steering wheel
- Used 72 spoke wheels
- Rear disc conversion
- Aluminum flywheel
Has anyone ever converted a Healey 6 to rack & pinion? What was the donor? How did it go?
Thanks,
Scott Graham
fordhealey
You can get rack and pinion conversion stuff by checking out
The Modified Austin Healey Registry site. lots of guys converted.Also some guys have left over parts from before their conversions.worth checking out.never hurts to have
an extra source of info.
gregg
Dave Russell
Yoda - R.I.P
Dave Russell
Yoda - R.I.P
[ QUOTE ]
What is the advantage of Rack and Pinion? /ubbthreads/images/graemlins/driving.gif
[/ QUOTE ]
To restate an earlier post;
R & P steering was largely adopted to make it easier to get the steering parts all in the correct locations as dictated by the body/chassis design. Also cheaper to make & less complex than any other type.
A worm & peg steering box, in good condition,can have just as good a feel & performance as a R&P. R&P's are also subject to their own set of wear & mounting problems.
The factory sales people were not about to mention that convenience & cost are the driving forces behind the new steering design & so hyped the largely imagined advantages which everyone picks up as gosple.
For the folks who are into engine transplants & other major modifications, the R&P offers a much simpler solution than the old style boxes.
T Wanted BJ7 parts needed Austin Healey Classifieds 0
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
S BJ7 Gearbox Parts Austin Healey 2
B Mechanical & body service parts manual BJ7/BJ8 Austin Healey 2
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
T Early BJ7 Vent Window Seal Austin Healey 2
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
D BJ7 Hood frame mounting plate Austin Healey 7
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
B BJ7 back end rebuild Austin Healey 1
Marvin Gruber BJ7 door panels Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Marvin Gruber BJ7 tach cable location. Austin Healey 3
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
