TR2/3/3A TR3A Rack and Pinion and Alternator in!!
CaptRoy
I continue to make progress with this project. I finished installing the Rack and Pinion kit and the alternator. Everything looks good and everything lines up like it's susposed to.. If I can get the header issue resolved I'll be ready to start this thing soon. I have another set of headers coming in and I'm going to use the set that fits best. If it's the new ones I'll be waiting for the Jet Hot coating before I can start it... We'll see...I received the carbs back from Gary Martin tonight and they are a work of art! I'll get a picture of them tomorrow...
Here some pictures of the rack and alternator installed for those that are interested.
The Alternator... https://www.capt-roys.com/alt.jpg
The Rack and Pinion... https://www.capt-roys.com/rack.jpg
Brosky
Roy, where did you ever come up with that alternator adjustment bracket??? I'd have given anything for one of those in the early 70's when trying to adapt alternators to various and sundry applications.
C
CaptRoy
Paul... That is a adjustment bracket from March Performance... It's not as easy as it looks... The hole was 3/8 and the bolt was 5/16.. I had to make a sleeve 3/8od and 5/16ID... Works great... I think I fitted that thing at least 4-5 times before I was satisfied!
bluemiata90
CaptRoy,
I just installed a rack and pinion kit in my 1961 Tr3. I don't have the engine in yet, so I'm not really sure how it's going to handle, but the wheels seem to turn much easier. My only question is, in the picture you posted, the right side u-bolt that holds the rack to the frame appears to not have the aluminum spacer/hold down. Is it just the picture of did that side not use one. I know I have one on both sides of mine. Just curious.
C
CaptRoy
It has a spacer... Just can't see it as I put it on the bottom as recommended by British Restorations. I hope it's right... Everything is real tight and it turns lock to lock with me outside the car.. I'm really looking forward to this upgrade..
startech47
When these cars are on the road be sure to let us know the results. I'm considering the steering rack change. If anyone already has a conversion on the road please speak up. What steering rack is used?
Thanks, Phil
TNTriumph
Where are you guys getting your rack and pinions. I have a 59 tr3a and I have been looking around. Also how much did you pay for yours.
martx-5
[ QUOTE ]
[/ QUOTE ]
I got mine from British Auto Restorations, 540-989-5121, VA. It looks like the same one that CaptRoy showed in his pic. The kit goes for about $1100. You have to remove the engine driven fan, so the kit comes with an electric fan.
C
CaptRoy
I got mine at the same place. That price sounds right for a split shaft column... May be a little higher for a single piece column... Very complete kit and installation was straight forward..
Deleted member 451
Got mine the same place. It's been on the road about 5 years now. Drives great, the allignment is easy and stable.
Because of my long legs I needed a smalled steering wheel the R&P makes using a 14" wheel easy. Handling is much better.
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
K TR2/3/3A DIY TR3A Rack and Pinion Steering Conversion Triumph 0
B TR4/4A TR4 to TR3A Rack & Pinion swap Triumph 4
60TR3A TR2/3/3A TR3A Conversion to Rack-&-Pinion Steering Triumph 33
T TR2/3/3A 1960 TR3A now with rack and pinion Triumph 22
T TR2/3/3A Best place to buy a rack and pinion for TR3A? Triumph 13
bluemiata90 TR2/3/3A TR3A rack and pinion conversion-yes or no Triumph 8
gsalt57tr3 TR2/3/3A TR3 [pre TR3a] Luggage Rack Triumph 7
jdubois TR2/3/3A Should be oil in a TR3A steering rack, right? Triumph 16
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
