OIl gauge lines on my 57
bnw
So why do I have about 10 inches too much OIL LINE when installing the new copper line and the new flex line? Coil it up? Leave out the flex line? Pictures anyone?
TR3driver
Great Pumpkin - R.I.P
Copper ?
Roger
Bronze
Copper line should be installed with a 360 loop in it. See any old Rolls for example.
TomMull
Not totally original, as you can see, but about 47 inches total (lost an inch or two with jury rig) with no loop. Original is steel. Tom
I Need help hooking up oil gauge lines Spridgets 5
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
Lairhead52 Wanted Oil Press Gauge Triumph Classifieds 0
L Oil Pressure Gauge Austin Healey 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
JimTR4 TR4/4A Oil gauge line Triumph 7
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
S TR2/3/3A oil gauge Triumph 7
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
JimTR4 TR4/4A Oil pressure gauge hose Triumph 5
BN6_2197 Question on Oil Temperature Gauge Austin Healey 1
T Oil Pressure Gauge Not Reading Spridgets 8
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
K TR2/3/3A Oil pressure gauge readings? Triumph 9
Rob Glasgow Oil gauge fluctuation Austin Healey 6
M TR2/3/3A Oil pressure: the gauge? Triumph 4
Rut MGB Oil pressure gauge leather washer MG 13
Geo Hahn TR6 Oil Pressure Gauge Triumph 4
maxwedge5281 oil pressure gauge line...urgent!!! Austin Healey 10
P Bugeye Water/Oil Combo. Gauge? Spridgets 4
K TR2/3/3A Oil pressure gauge indicator needle sticking? Triumph 10
P Bugeye oil/water gauge? Spridgets 6
PatGalvin TR2/3/3A Oil Pressure Gauge Leak - Leather Washer? Triumph 12
M TR2/3/3A Reading oil pressure gauge Triumph 3
K GT6 Spitfire oil pressure gauge readings? Triumph 4
pkmh Reinstalling oil pressure gauge in a BJ8 Austin Healey 4
BN6_2197 Oil Temperature Gauge for BN6 Austin Healey 6
P Mounting Bracket for Bugeye, Water/Oil Pressure Gauge Spridgets 5
NardisCNC Oil Pressure Gauge Questions..... Spridgets 8
JimTR4 Electric oil pressure gauge Triumph 20
Dougal BN1 Safety Gauge [oil pressure/water temp] number Austin Healey 4
T Oil Pressure Gauge braided line failure Austin Healey 6
luke44 TR2/3/3A TR3 Oil Gauge Line Triumph 3
J Oil/Water Gauge Austin Healey 5
S TR2/3/3A TR3A Oil Pressure Gauge Leather Gasket ?? Triumph 11
M Oil Feed Pipe to Dual Gauge Spridgets 9
D Oil pressure gauge flex hose. Spridgets 29
Stewart Removing the rectangular oil pressure gauge MG 5
sail Oil Pressure Gauge Stuck Triumph 4
