Gentlemen:
I've touched on this topic before, but I need more guidance:
- I have a 1275 in my BE. I have a plasic pipe with brass fittings on both ends. One fits to the block, the other goes to a another brass fitting as the end of a copper pipe that leads to the dual gauge. The plasit pipe has a hole in it and leaks a lot of oil.
- I ordered the pipe - rubber hose to gauge to block - and pipe - rubber hose to gauge, plus the rubber hose that connects the two together.
- When I tried to hook the pipe to the block I found the brass fitting to be 7/16ths while the one that came off the block (the broken one) is 3/8ths. What to do?
I checked the Moss UK books and they are indicating an adapter for the block. Should I remove the existing fitting on the block and replace it with this new fitting/adapter? is it possible to simply repair the old hose?
Any help will be appreciated. This is the only this standing betweeen me and the use of this car.
Mike Pennell
Mike Pennell
