Looks like I'll be building the Midget LE
G
Long story short, I've had it w/ rostyles and want to go w/ Challengers (when I can afford them). While I'm at it, might as well build the Midget that never was. I figure a LE Midget should have Challengers, at least a 3.55 and a/c. Yes, I said it, air conditioning. Kelly wants a/c and I like to give my wife what she wants.
A conventional auto a/c system doesn't make sense for one of these, so I was thinking of running a unit powered off of an inverter. NO, not a window unit! Of course I would have to change the alternator.
I was thinking about taking the componants out of a dorm size fridge and building a custom unit that would either fit in the glove box area, in the radio console ( move radio to rear panel or in trunk w/ remote) or putting it in the trunk and have it blow through the rear panel. I've also been thinking of mounting an evaporator in the heater core box and using those vents.
Does anyone foresee any problem with w/ using this type of system (dorm fridge) in a moble application w/ an inverter? (ie, compressor gulping oil). Any other ideas? ( gas fridge from an RV or a 12 volt unit from something else?)
I need a new dash anyway, so I might experiment with B vents in the Midget dash.
BTW, NO OVERDRIVE or five speed !!! I will not cut this car! (O.K, I'll drill a hole or two for a/c, but that's it and I don't mind a rear end swap.)
Hopefully this will be the first of many posts on this subject. Project will progress as funds allow. I don't foresee ever getting a V8B or a Sebring nosed Sprite, so I might as well have the only Midget LE. From what folks say I've got a really solid car, so I might as well. She deserves it and my wife does too.
scoutll
That should be something. I always thought they should have made an LE, or something similar.
drooartz
Go for it! Make it what you want it to be.
JPSmit
You do know that the top folds down right? Search some old threads and I think you'll find that Midgets are convertibles. :devilgrin:
seriously, why reinvent the wheel, there are neat electric AC units for the Hot Rod market. I just pulled this website out of a magazine. www.southernrods.com you might also find something for a boat.
G
Didn't know about that JP, thanks! Gotta have a/c down here in 110% humidity and 95*.
smaceng
Rather than use a 110 volt ref. unit, I would ditch the inverter and use a ref. that is wired for 12V, like the RV people use. Maybe mount it all in the truck, but have the ducts mounted over the tunnel to bring the air forward.
Good luck,
Scott in CA
G
I'd rather go 12v if avalible. I didn't know if they had them or not.
bthompson
Morris said:
I have long been flirting with the idea of making an AC/heating unit of peltier coolers.
https://www.virtualvillage.com/400w-12v-thermoelectric-cooler-peltier-plate-001540-017.html
That's just brilliant. I never knew stuff like this existed. Are you thinking along the lines of putting several of them right in the heater box, in a baffle sort of arrangement, with a drip trap and drain?
Using the center console might work as a separate unit...Make grilles for the radio and speaker holes; radio inlet, speaker exhaust; fan behind the speaker, drain thru the trans tunnel. Hmm...
What would the current drain on these things be? I assume our little Lucas alts couldn't keep up?
Morris
I have a 78 amp GM alternator, so I got room to spare. The plate in my link draws a little over 3 amps. I was thinking three of them would be required to achieve any real cooling. In my fantasy plan, I would make a custom box to mount them in that would replace the stock box. Heat sinks would be mounted on each side of the coolers, one on the inside of the box, one on the outside. In this way, the cool side is in the box, while the hot side vents to the engine compartment. Or reverse the polarity and you have a heater with the cold side venting into the engine compartment.
I guess you could make a box that mounts inside and come up with a coolant pump system to remove the hot/cold from the cockpit. Hmmm... that is actually a pretty good idea.
G
JP, I followed that link but can't find any 12v only stuff that doesn't use a belt driven comp.
bthompson
Okay, you've got me thinkin' about this now...I've been brainstorming ideas about using three peltiers in the center console.
You would build a little cool box out of 1/4" Foamcore. The peltiers would be mounted vertically with 1" finned heatsinks on each side. The hot side could have a surgical tubing arrangement in the fins. A little pump would circulate the coolant out the firewall and back in. The cold side would have a foamcore baffle to force all the incoming air, through the radio hole and over the fins. A little 3" fan (like the cheapo "personal cooling fans" from Wal-Mart) would be supported under the speaker hole. The foamcore would be cut around the fan like a shroud. The existing wiring harness and stuff would all be outside the cold box.
There'll have to be some provision to deal with the condensation, and it may be better to keep the fan motor out of the airstream somehow.
Come to think of it, it may be better to run the whole thing in reverse: since the cold dense air would flow down and out naturally, the fan wouldn't have to work nearly as hard. Of course, then you'd basically just be cooling off the shift boot. :smile:
Food for thought, anyway!
lesingepsycho
In 2005 I remember reading that a couple of teenagers had built an automotive AC using the peltier devices. They won an award for developing Freon-less AC. Read an article about them here. At the time it was a big deal and I haven't really heard anything further about it until now.
I know I have played with Peltier devices before like at the local Oregon Museum of Science and Industry (OMSI) and the amount of heating and cooling put off by these devices seemed very small though intense but with little convection/radiation. It almost seems like you would have to mount them to a water jacket to get a direct conduction transfer of energy (heat or cool) and then circulate the conditioned water past a fan. Just blowing air across the top of a Peltier chip doesn't seem like it would be too effective though. Whatever the case, I'm surprise that there really hasn't been any developments in this field (especially considering that the Peltier effect was discovered in 1834! It seems like it would be low maintenance and long lifespan. Oh, and according to the article, even recyclable!
JACK
G
This is probably what you're talking about:
https://www.southernrods.com/categories/h...product-11.html
Doesn't seem bad to me and should (hopefully) be able to replace the heater box under the hood and blow through those vents. You could use the ducting to direct the air up under the dash and blow in your face. I'd pay $400 for that. That might just be the ticket. Thanks JP!
JPSmit
that's the one, glad you found it. Please Please document this - pics and explanations. This is new territory and worth remembering.
S TR2/3/3A I've been wrong for 60+ years: it looks like it's NOT a 1959 Triumph 8
Sarastro TR4/4A Looks like I need a new ring and pinion... Triumph 30
PeterK TR4/4A Here's what my NOS 511695 cylinder head looks like, unboxed Triumph 10
RickB MGA Looks like a nice MGA grille, $50 on Seattle Craigslist MG 1
Healey Nut Looks like prices are on the way up again Austin Healey 28
C Smaller diameter steering wheel - that looks like stock? Austin Healey 16
drooartz Looks like I'll get some more engine removal experience Spridgets 31
max71 MGB Here's what the inside of a MGB mechanical gauge looks like MG 0
M General TR looks vs. function? Triumph 8
bugedd Looks like you guys are stuck with me Spridgets 10
Tinkerman TR2/3/3A It's installed, It fits, It looks great, I'm excited!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Triumph 8
JPSmit why must I always be tempted so - it looks terrible on the resume! Other British Cars 5
JPSmit This looks tasty 'Vette from Bring a Trailer Other Cars 7
RickB Looks like I'm going to be driving to South Dakota again! Spridgets 12
aeronca65t A-H 3000 for sale - looks like a real barnfind Austin Healey 7
Simmo This looks like spring sag. Triumph 4
Lukens Looks like someone got a deal. What do you think? Triumph 18
D Looks and sounds Brit to me. British Motorbikes 3
C Stag Looks like a real nice Stag Triumph 8
T Looks like I have got bigger OD issues... Triumph 43
regularman Well, looks like I will be tearing into the 1500 Spridgets 22
Got_All_4 This looks like fun! Triumph 1
davester Inexpensive California RB on craigslist-looks good Spridgets 5
jackq End of road for a 72B..looks like MG 16
RickB Looks like an honest $4900 Bugeye Spridgets 3
T OT - looks like the Volvo is out, because.... Triumph 26
JPSmit This looks like a steal to me MG 9
T Almost looks stock - really nice build Triumph 8
JPSmit Looks like Joe is clearing his stuff Other British Cars 24
drooartz Terri, This looks familiar... MG 3
deadair TR2/3/3A This is what it looks like in TR3 heaven Triumph 11
H the first time I see this. looks interesting Triumph 4
tomshobby Looks like I am going to own a Midget Spridgets 7
DarwinT I don't like the looks of this Spridgets 25
1 I like the looks of TRIPOD headlights... Spridgets 2
JPSmit Trailer - now this looks cool Restoration & Tools 5
W This looks like a deal Spridgets 17
philman This looks like the wedgie for someone?! Triumph 7
S I hope my car looks HALF as good as this one...... Jaguar 6
roofman Looks like Dale made the cut! Triumph 13
JPSmit Looks like no LoO Spridgets 2
B TRSC's Great Looks/Great Books @ Autobooks Triumph 1
philman How my engine bay looks now Triumph 3
toysrrus Puerto Rico Golf Open - Weather looks Good! Triumph 13
healeyboz This looks fun! Spridgets 2
BIBBER stay with me looks like I got thehots for South!!! Other Cars 7
Brosky TR4/4A TR4 eBay looks like FUN Triumph 17
gsalt57tr3 looks like, smells like a scam, might be a scam Triumph 7
philman I've never seen one, but this looks fun MG 4
jlaird Looks like a new bugeye to me Spridgets 2
