Lockheed Booster
dancrim
Took out my Lockheed booster to find out why my brakes act like there is no booster. Discovered the cap, filter, foam washer and spring are missing. Could this be my problem? Any Ideas on where I can get these parts? Moss is all NA on them. Thanks all.
Keoke
Try Healey Surgeons , Power Brake exchange or Whit Post restorations.?
Patrick67BJ8
Power Brake Exchange is about $300 and they will not sell you the parts so you must have them rebuild your unit.
RAC68
Hi Dan,
A while back I, was initially unable to acquire an air valve and could not complete the rebuild of my Girling brake booster. I replaced it with a Lockheed unit and although the booster performed well, it assist was not a substantial as I had grown to expect from the Girling booster. Eventually, I was able to acquire an air valve and completed the Girling booster rebuild and reinstallation. Although I believe your missing parts could be the source of your present problems and would contact those sources indicated by Keoke, I was also told that Hydroboost (https://www.hydroboost.com.au/) out of Australia, may be able to provide Lockheed parts, set performance expectations for your unit, and/or even supply an alternative PBR booster.
Hope this helps,
Ray (64BJ8P1)
S Lockheed Vacuum Brake Booster Austin Healey 10
S TR2/3/3A Lockheed brake system Triumph 7
fundytides Bleeding Lockheed Brakes on 1951 Vanguard Other British Cars 11
CJD TR2/3/3A Lockheed Axle Triumph 8
CJD TR2/3/3A Lockheed Dif seals Triumph 5
R TR2/3/3A Lockheed diff setup Triumph 6
T TR2/3/3A 1956 TR3 with Lockheed Drums to Disc Questions Triumph 11
R TR2/3/3A Lockheed axle questions Triumph 8
N Lockheed brake assembly grease??? Spridgets 2
M Orientation of Lockheed brake servo Austin Healey 2
mgedit TR2/3/3A Master Cylinder 56 TR3 [Lockheed] Triumph 14
2 TR2/3/3A TR2 Lockheed Hubs - Disc Wheel Triumph 3
2 TR2/3/3A Lockheed Master Cylinder Triumph 1
mgedit TR2/3/3A Bleeding Lockheed Master Triumph 7
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
mgedit TR2/3/3A Lockheed Master Cylinder 56 TR3 Triumph 2
C TR2/3/3A TR2 Lockheed brakes Triumph 13
mgedit TR2/3/3A Replacing Lockheed Axle Seals 56 TR3 Triumph 25
K TR2/3/3A Lockheed Diff...why is it considered 'weak"... Triumph 3
CJD TR2/3/3A Lockheed Axle Triumph 32
CJD TR2/3/3A Early Lockheed Master Cylinders Triumph 24
mgedit TR2/3/3A Lockheed Diff Oil Seal Replacement Triumph 10
2 TR2/3/3A TR2 Lockheed axle? Triumph 9
mgedit TR2/3/3A 56 TR3 Lockheed MC Reassembly Triumph 8
J TR2/3/3A TR3 Lockheed brake/clutch MC bracket... Triumph 11
E 1275 Brake MC Lockheed vs Lucas Spridgets 0
N Lockheed servo photo Austin Healey 2
N Brake Servo Lockheed Austin Healey 0
YankeeTR TR2/3/3A I need some info on broken TR2 Lockheed axles..... Triumph 0
Sopwith_Camel MGA booster Vacuum MG 8
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
G Adding a Brake Booster / Brake Calipers Austin Healey 3
G Brake Booster Failure Symptoms Austin Healey 3
drooartz MGB Swapping to dual SU on later MGB with brake booster MG 7
glemon General Tech Brake Booster Happy Camper Triumph 0
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
J Powertune booster for a bj8 , trouble installing Austin Healey 2
glemon TR5/TR250 Brake Booster Triumph 2
Marvin Gruber BJ8 brake booster Austin Healey 6
Marvin Gruber Big Healey brake booster rebuild Austin Healey 4
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Marvin Gruber BJ8 brake booster picture Austin Healey 4
G Brake Booster Replacement Air Filter Austin Healey 4
BOBBYR BJ8 Brake Booster Austin Healey 13
sundown TR6 1973 TR6 brake booster hose Triumph 7
RAC68 Alternative Remote Brake Booster Austin Healey 3
cyurasko Child Booster Seats Triumph 10
T Brake booster rebuild Austin Healey 4
