Brake Booster Replacement Air Filter
Administrator
Boss
Welcome to BCF! You posted in the new member introduction forum where you are meant to intoduce yourself. I'm moving your post to our Austin Healey forum where you are likely to get more replies.
Brooklands
Welcome to the Best forum for Little British Cars. Glad to find another member from the WLVT area. I am sure that Basil's transfer of your post to the AH forum will help you get some more information for your quest. And in the meantime, please tell us more about yourself, and your car. And be sure to add a photo or two as well.
RAC68
As I understand, the filter you are looking for was used on a Girling Servo Mk 2a and 2B. The number presented seems to have been replaced by #600561 and can be found on eBay in the UK. Check eBay and look at the picture to make sure it is what you want.
Hope this helps,
Ray (64BJ8P1)
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
G Adding a Brake Booster / Brake Calipers Austin Healey 3
G Brake Booster Failure Symptoms Austin Healey 3
drooartz MGB Swapping to dual SU on later MGB with brake booster MG 7
glemon General Tech Brake Booster Happy Camper Triumph 0
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
glemon TR5/TR250 Brake Booster Triumph 2
Marvin Gruber BJ8 brake booster Austin Healey 6
Marvin Gruber Big Healey brake booster rebuild Austin Healey 4
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
Marvin Gruber BJ8 brake booster picture Austin Healey 4
BOBBYR BJ8 Brake Booster Austin Healey 13
sundown TR6 1973 TR6 brake booster hose Triumph 7
RAC68 Alternative Remote Brake Booster Austin Healey 3
T Brake booster rebuild Austin Healey 4
P BJ8 Brake Booster mount Austin Healey 9
C Vacuum line routing for brake booster Austin Healey 5
TRclassic3 Brake booster TVR 2
Gliderman8 Brake booster rebuilder Triumph 5
Got_All_4 Wedge TR7 brake booster Triumph 18
tinman58 TR5/TR250 TR250 brake booster Triumph 2
W Brake fluid in Servo/booster Triumph 5
PAUL161 Chevy P 30 chassis brake hydro booster? Other Cars 0
66healey Aftermarket brake booster pictures Austin Healey 7
J TR6 70 TR6 Brake Booster Triumph 4
B Brake Booster Austin Healey 2
E installing AP brake booster Austin Healey 3
Patrick67BJ8 Brake Booster Repair Vendor Austin Healey 21
rjc157 Powertune Brake Booster Austin Healey 0
Basil COrrect plating for Brake Booster? Jaguar 9
nissanite TR6 TR-6 brake pedals in a TR4A including booster &... Triumph 30
B rebuild of brake booster Austin Healey 6
D Wedge Power Brake Booster/Master Cylinder for TR7 Triumph 4
J Rebuild brake booster? Austin Healey 0
A brake servo booster help Triumph 3
R Painting the Power Brake Booster Triumph 11
BOBBYR Girling brake booster Austin Healey 5
N Brake booster rebuild Triumph 3
kyreb1862 Brake Booster Install MG 0
I TR6 69 TR6 brake booster Triumph 2
VelodromeRacer Brake booster hissing... Austin Healey 9
N Vacuum leak at Brake Booster? Triumph 15
B TR6 TR6 Brake Booster/MC Rebuild Triumph 5
WALTER BJ8 w/o brake booster? Austin Healey 4
S HELP! with vacuum brake booster Austin Healey 4
S Brake booster vacuum cylinder cover color... Austin Healey 2
Brosky Brake Booster Rebuilding Triumph 9
2 Brake Booster Triumph 3
kyreb1862 MGB 77 MGB Brake Booster Color MG 5
kyreb1862 MGB MGB Brake Booster Diagnosis MG 1
