Re: HIF Throttle Disc - DOC
PAUL161 said:
Thanks Hap, I wasn't going to pull the carbs off until I had the butterfly's in hand, but I guess I'll have to pull one just to see which ones I have. Been a while since you rebuilt them, so that's asking too much for you to remember which ones they are. Thanks a bunch for the info! PJ
Either way, you'll still be getting the solid early butterfly, there's only one solid butterfly for HS4s, so you can't order the wrong thing, They don't make a notched solid butterfly, you have to do that the butterfly yourself for the raised tube HIF4s. Gordon has the solid butterflies in stock, and can get them to you in a hurry, next day shipping for us, at ground prices :banana: Get a set of new split screws as well for the butterflies, use a little loctite on them.
As for the mod if needed, either notching the butterfly or flushing out the idle enrichment tube, you still have the right butterfly, anything to get rid of those pesty poppet valve butterflies.
Pay close attention to the orinetation of the butterfly, it's opposite on HIF4 than a HS4 as far the way it leans at closed postion, but the angle on the edges of the butterflies only seal one way, so look at that closely when you take yours apart.
