Call Joe Curto , he ca fix you up, warning some HIF4s will have a tube at the butterfly opening, it's an enrichment tube, some of the tubes sit up proud and the btterfly has to have a notch to clear it, some are flush with the bottom of the carb body. If you have the flush tube, the sold HS4 butterfly will go in without any mods, but if you have the tube that sticks up, then you have two choices, notch the butterfly to clear the tube or flush the tube out with the bottom of the carb body, I prefer flushing the tube out with the bottom of the carb body, this will always lend itself to a better idling carb.
