Legal Bill
Now that my car is all restored to original and I've driven it around a bit, I am formulating a list of upgrades that I think I will want to make to the car if I choose to drive it more than just look at it in the garage. All items are easily reversible if I want to return the car to bone stock. Here is my list so far. Any thoughts, good or bad about the items listed? Anything I missed?
1. Petronix under cap electronic ignition.
2. Spin on oil filter adapter.
3. In line gas filter (already done).
4. Negative camber shock bushings.
5. Slightly wider 72 spoke wheels and 185 tires (already done).
6. Texas cooler fan.
7. Coolant recovery tank.
8. Convert car to negative ground (not easily reversible due to the fuel pump and tach changes that are needed here).
9. Instal an alternator kit (kinda goes with number 8 above).
10. AM/FM stereo radio with two speakers mounted somewhere under the dash ( will probably not be doen until I convert the car, but who knows).
11. Numerically lower rear gears.
12. Pedastal for rear view mirror, probably the one with a clock in it.
13. Wing mirrors (already have them, just can't bring myself to drill holes in the fenders and yes, I know it is not easy to reverse this).
14. Wood steering wheel and gearshift knob (already done, but I need a different shift knob because the one they sent me is redish rather than walnutish in appearance).
15. Lucas Sports Coil (already installed).
16. Gear reduction starter (probably a long way off as the original one seems to do the job just fine at the moment).
17. Seat belts for the back seat if I can figure out how to mount them without drilling more holes in the car.
18. Halogen sealed beam headlights (already installed).
That's my list. Fire away!!!
