TR2/3/3A TR2/3 Front Suspension Upgrades
WiscTR
As the outdoor projects wind down, I am looking at beginning to re-assemble the TR3 parts onto the Ratco frame. Does anyone have any experience with the new vertical links with negative camber, or with the three degree castor trunnions? They are available new from a number of suppliers but are quite pricey. Swapping in a used assembly from a TR4IRS or later model would be more economical, but is there enough improvement to be worth it?
2long
Seems like if you were looking for a real suspension upgrade, a rack and pinion set up with the TR4A negative camber trunnion/vertical links would be nice on a TR3. Don't know if the TR3 Ratco frame would accommodate the rack and pinion, but worth looking into.
Dan
2long
This is from the Wizard of the Desert, Robert Schaller. A great TR enthusiast and fine man who helped me out a lot.
Dan
W
WiscTR
The Ratco frame is powder coated and foam filled. No opportunity to practice welding on the frame -- I am saving that for the body panels �� I made the decision to not change to R&P steering before I purchased the frame.
The castor/camber change is being considered because of corrosion in the upper arms and bends in two of the three vertical links that I have available.
I just don't know how much improvement, if any, will result from these proposed changes. Obviously, originality is not a concern with the new frame.
TR4nut
Sorry for not chiming in earlier. On the TR3A project I recently sold I converted the TR3 setup to a late TR4 setup with the castor built in. Easy change, used later trunnions and then was able to use upper arms/balljoints for the late TR4-TR6. As to driving change, well, I never got that far!
Does your Ratco frame have a setup for the lower arms that lets you adjust camber, or is it just like a TR3/4 frame? If you haven't seen it, Tony Drews has a very good writeup on how to upgrade to TR6 parts here:
https://tonydrews.com/Front_Suspension/tr4_front_suspension_upgrade.htm
The vertical link is stouter so may be an improvement for you - I was considering doing the same thing. But note you may need to add spring spacers to the front to get the ride height you want, the vertical link change will lower the car.
TR-3rg
Hi, Here are a couple more links that might help:
https://www.tr3a.info/Net.htm scroll this for a couple of good front and rear suspension discussions
www.tildentechnologies.com/downloads/TRsuspension.PDF
I have the Revington Upper Fulcrum Kit, (RTR3112K) on my TR-3a. If you go this route, read the Revington pdf sheets carefully. It can easily cost double with the parts that are needed to finish the job. In addition to what's listed on the sheets, added the TR-4A front brake lines because I am running the TR-6 15"x 6" wheels. The TR-3 brake line rubbed the tires with the new front end settings.
Good luck, Roy
W
WiscTR
2long,
Thank you, I have a copy of 'More Bs about TRs' -- it's quite interesting. I met Bob Schaller in the 80's at a Triumph convention in St Charles, IL. Quite the character and he had many TR stories.
Didn't even look at the TR today -- must have been one the few days all year when the weather in WI was nearly as nice as the weather in HI��
W
WiscTR
TR4nut,
The Ratco frame is mostly a heavy duty copy of the TR frame, although I believe that Tony V. could make whatever you wanted -- might cost you a bit, though :smile:
Thanks a bunch for the Tony Drews link. It has all of the info you would want about making the change -- now, it is worth it?
W
WiscTR
TR3-rg,
Thank you.
The Tilden Tech link is more than I can get into on a post Packer game evening��, but looks to have some good info.
Can't believe that I forgot about TerriAnn's NetNuggets.
The Revington kit is the one that is welded once you have everything sorted, isn't it? Will check it out. Man, Revington has a lot of really interesting stuff, don't they? Wish the budget was bigger -- or even that my connection was faster than DSL��
TRMark
Bronze
I added to the "pockets" of the upper a arms, slotted the upper ball joint mounts and moved the ball joint inwards. Use washers between the bolts and a arms, weld the washers to the a arms when you have them adjusted to the desired camber. I can post some pictures when I get home if you like. I can also measure how far I moved the ball joints inwards, iirc (more doubtful as I get older) it was about 3/8".
W
WiscTR
Thank you, pics would be good. By 'added to the pockets', do you mean that you altered cylinders for the bushings as opposed to changing the lenght of the arms? That would be quite different and the pics should be very interesting.
TRMark
Bronze
Oh no, I am an idiot. I forgot the upper a arms on the 3 and early 4 are much different than the ones on my later 4. I apologize didn't mean to confuse things.
W
WiscTR
I did go out into the garage to look at the arms again to see if I was missing something ��
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
J TR2/3/3A TR2 - earlyTR3 front brake hose length and photo? Triumph 1
Andrew Mace TR2/3/3A TR2/3/4 Girling front shock ID? Triumph 1
Tinkerman TR2/3/3A TR2 Front Flasher Lenses for Trade Triumph 1
A TR2/3/3A TR2/3 bumper vs TR3A bumper [front] Triumph 23
Banjo TR2/3/3A needed TR2-3 front fenders Triumph 0
gsalt57tr3 TR2/3/3A TR2 vs TR3 front apron Triumph 4
Nanhook TR2/3/3A TR2 shoes Triumph 2
CJD TR2/3/3A TR2 Annual Triumph 6
S TR2/3/3A WTB a tr2 original grill Triumph 0
P TR2/3/3A TR2 Horn Mounts Triumph 7
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
S Wanted tr2 original grill Triumph Classifieds 10
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
A TR2 Transmission overhaul Restoration & Tools 0
D TR2/3/3A TR2 Flying Mile question Triumph 11
S TR2/3/3A tr2 muffler clamp Triumph 10
Southwarks TR2/3/3A TR2 door help! Triumph 2
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
A Wanted Girling Axle for TR2 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
S TR2/3/3A tr2 and tr3 back trim above the back cover Triumph 0
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
S TR2/3/3A tr2 Triumph 18
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
P New member TR2 carpets Triumph 7
S TR2/3/3A Tr2 hood Triumph 8
W TR2/3/3A TR2 wiper motor mount Triumph 1
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
Jim_Stevens For Sale New TR2-3A inner sill assemblies Triumph Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
P TR2/3/3A TR2 color questions Triumph 23
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
