TR4/4A TR4-6 Steering Upgrades
glemon
There have been many discussions of poly bushings and solid steering rack mounts to get better steering feel on our rack and pinion TRs. I did read one post a few weeks ago that got me to thinking (always dangerous) sorry, I don't remember who, but somebody mentioned replacing the top rubber universal in the steering shaft with the solid one from the lower shaft. This sounds to me like it would have more effect on steering feel than the rack bushes. Anyway, I am considering either doing the solid rack mounts or the solid upper mount on the column. I would think from an engineering standpoint the rubber rack mounts would be more important for absorbing shocks and saving stress on the rack than the rubber coupling in the shaft. If you have ever driven a Sprite/Midget you know how precise and direct rack and pinion should feel, trying to get the TR a little closer to that type of steering feel.
richie
I can report that after replacing just my upper with a solid TR6 joint, I noticed a massive improvement in feel (along with Arthur Lipp's Delrin column bushings). This winter during the projects I will be replacing the lower with a universal joint as well. I didn't notice any vibrations that were unwelcomed!
DNK
In my 73 Capri
That change had the biggest effect on the rubbery steering known in those cars
Always wanted to do it in the 6 and constantly asked if anyone had seen a solid version
Darrell_Walker
I've replaced both of the rubber joints in my 4A with the solid ones from the TR6, I have solid rack mounts, and even a quick-rack. I love the steering feel!
DNK
Aren't we talking about the upper coupler?
If not...my bad
richie
Yes but I thought I would through my 2 cents in as only the 6 cylinder models came with a solid below and the others came with rubber joints. Upgrading 1 made a huge difference, the only remaining play I have left in my rack is due to the remaining lower rubber coupler.
Darrell_Walker
In that case, I wonder if a CV type joint could be adapted.
Probably, the advantage of the TR6 steering u-joint is that it is a perfect fit over the existing shafts.
glemon
glemon
Was warm in the garage yesterday, I finished installing the new rubber rack bushes, I squeezed them up tight against the frame on the sides as mentioned on other threads here (BTW I didn't need any special tool just used a couple vise grips, a little finicky to get them placed right, but easier than fabricating a special tool). Took the car for a drive and the steering felt improved, I also now have an extra solid lower U joint, but it doesn't look like it can be installed without some adapting, the rubber coupling goes on a splined end on one side and bolts to the shaft on the rack side, the U joint is meant to go on splined ends either way. Anybody run across this and if so how did you make it work?
richie
The fitting that appears to be bolted to the shaft on the rack side should also be removable.
Here are some pics from my car:
glemon
glemon
Thanks Richie, My intermediate shaft is does not have a splined end like that, I have some old TR4 parts in the basement, and know I had a steering shaft at one time, but might have given them up to friends with TR3s looking for parts for Rack and Pinion conversions.
TR4nut
And I was thinking the TR4 lower shaft was shorter than on a TR250 or TR6? Didn't the rack move forward a bit to accommodate the 6 cylinder engine?
HerronScott
As I recall when I converted my TR4A to use a TR6 lower U-joint, I had to use a TR6 lower shaft.
Scott
Foura
After reading this thread, I ordered a couple of solid steering joints for the 4A. I put them on last week. The lower joint came off easily because of a bit of oil mist from the front of the engine ( on a British car?? No!) but the upper one needed a large amount of persuasion. I used some Copper Eze on the splines on re-assembly in case I ever have to take them off again. We went for a 300km drive with the Datsun Sports Car Club (who?) last weekend over some very twisty roads. This would have to be one of the best mods you can make to a 4A. The steering was lighter and much more responsive and kickback on our rubbish roads was not an issue. And those Datsun guys travel FAST! We were doing 85mph at one point just to keep up.
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
KVH TR4/4A TR4 Steering--Just a Question I've Always Had Triumph 1
TRMark TR4/4A Strengthening early type TR4 steering rack mounts Triumph 4
B TR4/4A TR4 steering rack Triumph 2
H TR4/4A tr4-a steering parts Triumph 3
KVH TR4/4A TR4 Steering Rod Splines Triumph 2
T TR4/4A How do YOU fit steering rack bushings on TR4-6s? Triumph 6
M TR4/4A TR4 Steering Wheel Triumph 6
KVH TR4/4A TR4 Steering Rack and Alignment Questions Triumph 7
T TR4/4A TR4 Steering Up-date Triumph 0
thechileman TR4/4A Replacing TR4 Steering wheel Triumph 10
T TR4/4A tr4 steering column-replace rubber with u-joints? Triumph 9
T TR4/4A Early TR4 Steering Triumph 2
KVH TR4/4A TR4 Steering Rack Problems Triumph 0
T TR4/4A tr4 steering wheel-modifications Triumph 8
M TR4/4A TR4 Steering column coupler Triumph 5
T TR4/4A anyone have tr4 steering arms? Triumph 0
M TR4/4A TR4 Steering Racks Triumph 5
bravenrace TR4 Steering Arm For 2500M? TVR 5
SCguy TR4/4A TR4 Steering Rack? Triumph 2
SCguy TR4/4A TR4 Steering column threads ? Triumph 1
SCguy TR6 TR4/TR6 Steering rack question Triumph 9
D TR4/4A tr4 steering - inner ball joints loose Triumph 14
KVH TR4/4A Bushing Torque and Steering TR4 Triumph 3
TR4nut TR4/4A Opinions on a TR4 steering wheel replacement? Triumph 12
M TR4/4A TR4 Steering Rack - play Triumph 4
Alan_Myers TR4/4A TR4 steering column bracket Triumph 7
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
