TR4/4A TR4 Steering Rod Splines
KVH
I'm sorry to report that once again I had to try to improve something.
The splines on my steering rod appeared rusted and caked with dirt, and I was concerned I'd have corroded, rusted steering rods that eventually would be a problem.
So, using a little puller, I pulled the female splined parts off each rod end, and cleaned both ends with a stiff brush and some lubricating oil.
Now they look nice, but they seem too loose. They slide apart until stopped by the little thru-bolts.
There seems to be some slight play in the fittings as well, maybe a few 1000s.
Is the sliding normal, acceptable? Do I now need to try and pinch those splined fittings so they fit more tightly, or is there supposed to be some clearance and play in the splines.
Thx
TR4nut
Just a guess, but I don't think you want any play at all there. For one, that is the ground path for your horn. And more importantly if there is play in the long term there will be increased wear and that is an area you don't want to fail. Any chance you can put in a grade 8 pinch bolt and tighten them back down?
TR3driver
Great Pumpkin - R.I.P
Definitely pinch them until they lock. If all else fails, add something like Loctite RC609 to lock them.
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
KVH TR4/4A TR4 Steering--Just a Question I've Always Had Triumph 1
TRMark TR4/4A Strengthening early type TR4 steering rack mounts Triumph 4
glemon TR4/4A TR4-6 Steering Upgrades Triumph 15
B TR4/4A TR4 steering rack Triumph 2
H TR4/4A tr4-a steering parts Triumph 3
T TR4/4A How do YOU fit steering rack bushings on TR4-6s? Triumph 6
M TR4/4A TR4 Steering Wheel Triumph 6
KVH TR4/4A TR4 Steering Rack and Alignment Questions Triumph 7
T TR4/4A TR4 Steering Up-date Triumph 0
thechileman TR4/4A Replacing TR4 Steering wheel Triumph 10
T TR4/4A tr4 steering column-replace rubber with u-joints? Triumph 9
T TR4/4A Early TR4 Steering Triumph 2
KVH TR4/4A TR4 Steering Rack Problems Triumph 0
T TR4/4A tr4 steering wheel-modifications Triumph 8
M TR4/4A TR4 Steering column coupler Triumph 5
T TR4/4A anyone have tr4 steering arms? Triumph 0
M TR4/4A TR4 Steering Racks Triumph 5
bravenrace TR4 Steering Arm For 2500M? TVR 5
SCguy TR4/4A TR4 Steering Rack? Triumph 2
SCguy TR4/4A TR4 Steering column threads ? Triumph 1
SCguy TR6 TR4/TR6 Steering rack question Triumph 9
D TR4/4A tr4 steering - inner ball joints loose Triumph 14
KVH TR4/4A Bushing Torque and Steering TR4 Triumph 3
TR4nut TR4/4A Opinions on a TR4 steering wheel replacement? Triumph 12
M TR4/4A TR4 Steering Rack - play Triumph 4
Alan_Myers TR4/4A TR4 steering column bracket Triumph 7
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
