Seatbelt modifications & upgrades
Bret
Ok I’ve got a problem and am looking for options.
As some of you know about a year & a half ago my wife & I purchased a new GMC Envoy Denali XL fully loaded with every bell & whistle available plus a few dealer options. It is my wife’s daily driver, kid hauler and grocery getter. While the wife loves it – there is one thing that bugs her.
The integrated seatbelts are built into the front seats and cut into her shoulder. This over time has caused a dull ache in her shoulder & collar bone. We’ve tried the seatbelt shoulder pads and have even tried to see if there is a way to adjust the tension. But we haven’t had any luck.
So I’m considering taking the vehicle to a custom or upholstery shop that might be able to help. The idea is to keep the belt tensioner in the seat but have a swivel piviot anchor point located on the “B” pillar to relive the pressure coming across the shoulder. Problem is this vehicle has the integrated side curtain airbags and I really don’t want to tamper with those and would prefer a professional installer/custom shop handle this for us.
Any thoughts on this? While the vehicle isn’t my cup of Joe, it’d sure be a shame to sell it without at least considering some other options first.
Mickey Richaud
Well, I'm not sure I have any bright ideas, but I am surprised that there is no adjustment for height on the belts. I thought just about all newer vehicles had that feature. Guess their being integrated into the seat nixed that. Hope you can resolve it, 'cause if you have to trade, it'll surely cost ya.
Mickey
JerryB
"""""The integrated seatbelts are built into the front seats and cut into her shoulder. This over time has caused a dull ache in her shoulder & collar bone. Weve tried the seatbelt shoulder pads and have even tried to see if there is a way to adjust the tension""""""""
Trying to get someone to modify a factory belt installation might be problematic....competency and liability might be a factor.
You mention "seatbelt shoulder pads".
I use a pad made for 2" shoulder belts about 9" long that "wraps" the belt with a velcro closure and slides up or down the belt and adjusts at your neck after you buckle up. These come in sheepskin or fabric ...I found some decent and comfortable ones at the 99 cent store but have seen then at Auto Zone etc. in the ricer section at a hugely infalted price.
Plan "B" might be a trip to your friendly GM dealers Service Manager ?....GM might have a fix due to many complaints...
I've seen a plastic doohickey that pulls the shoulder strap more to the center of your lap (my wife does it with those cheap aluminum d-clip keyrings, as she too has the same problem in almost every car we own).
foxtrapper
Tension can be adjusted, but you'll have to do it. No dealer will touch this job. It will affect the rewinding capability when you're done. Just disassemble the seat enough to get the unit out, then disassemble the unit, and unwind the spring. It's easier to do than you think, and I've done this sort of job a number of times on various automatic seatbelt winder units.
Another free and easy alternative is to use a brooch. And since it's her vehicle, this should work well. Have her get into it and buckle up. Pull the seat belt forward a bit, and pin the brooch into the webbing so that it hits the plastic trim on the seat where the webbing goes in. Adjust the brooches position until it's just slack enough to be comfortable for her. Obviously the seat belt will not longer retract, so she'll have to be a little carefull about not slamming the door on the buckle or leaving the webbing hanging out to get wet in the rain.
Paul Johnson
Or just pull the shoulder harness out a hair from it's position when she is driving and place a spring loaded clothes pin on it to maintain the position. At least that should work until you can find something pretty looking.
C TR6 Seatbelt anchor points Triumph 2
W Seatbelt Anchor Points Austin Healey 2
drooartz Seatbelt mounts for Bugeye Spridgets 28
P TR6 Tangled seatbelt Triumph 3
H correct BJ8 seatbelt Austin Healey 13
Patrick67BJ8 Seatbelt Reinforcing Plates for BJ8 Austin Healey 3
C vintage style seatbelt installation 1965 MG Midget Spridgets 4
P stuck seatbelt '79 midget Spridgets 3
Cookie Last one for today-promise! Seatbelt help needed! Spridgets 4
H TR2/3/3A SECURON INERTIA SEATBELT ON TR3A Triumph 5
P stuck seatbelt retractor Spridgets 7
C Seatbelt install points Spridgets 13
poolboy TR6 74 TR6 "seatbelt module" Triumph 14
K Seatbelt Modules MG 13
Randy Harris I need a seatbelt restorer Jaguar 1
Randy Harris Seatbelt restoration vendor? Austin Healey 5
MadRiver TR5/TR250 TR-250 Seatbelt Questions Redux Triumph 4
Guinn Seatbelt holders MG 3
Bret T-Series Seatbelt latch sensor? MG 3
Guinn Possible seatbelt holder? MG 3
Stewart Prestige Autotrim seats covers and seatbelt ? MG 2
mlarnoldTR6 3point seatbelt question Restoration & Tools 5
G MGB 71 MGB Seatbelt Retrofit MG 0
D Spridget Modifications Spridgets 12
glemon Spitfire Modifications are a matter of taste and personal preference I guess Triumph 3
RAC68 Suspension Modifications to improve Handling and Roadability? Austin Healey 96
J Seat modifications Austin Healey 9
davidk TR6 Modifications to Datsun Aluminum Drums - TR-6 Triumph 16
Simmo TR2/3/3A TR3 Indicator modifications Triumph 1
HealeyPassion Tunnel modifications for 5-spd conversions Austin Healey 15
Lin Side Curtain Modifications to eliminate noise Austin Healey 25
C Performance Modifications Triumph 3
T TR4/4A tr4 steering wheel-modifications Triumph 8
J Timing a MG 1500 with modifications Spridgets 7
Johnny AH 3000 BN7 rear leaf springs modifications. Austin Healey 4
bighly Poll - Upgrades and modifications Austin Healey 11
Dugger Spitfire Spitfire Frame Modifications Triumph 7
T steering rack modifications Triumph 0
prb51 TR2/3/3A Tr3 modifications Triumph 14
S Modern Modifications Spridgets 10
M TR2/3/3A Tasteful Upgrades Triumph 15
tr6nitjulius For Sale "SOLD" Winter projects: Upgrades 4Sale or Reasonable Best Offer Triumph Classifieds 0
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
Michael Oritt Brake Upgrades Austin Healey 5
J BT7 [Tri-Carb] Restoration Upgrades Austin Healey 2
T Tasteful Upgrades for a Bugeye [part II] Spridgets 5
T Tasteful Upgrades for a Bugeye Spridgets 8
JimLaney Sprite MK III upgrades - recommendations? Spridgets 23
F For Sale suspension upgrades TR6 Triumph Classifieds 0
T Tasteful Upgrades to a BJ7 Austin Healey 24
