TR4/4A Engine upgrades from a TR4a - what to get?
TR4nut
I thought I read an earlier thread on this, but I haven't had luck searching. I am potentially 'upgrading' my TR4 using stock 4a parts. So far I've amassed an exhaust manifold, SU intake setup, cylinder head, and distributor. Should I be grabbing the camshaft too? Anything else?
I have a small window of opportunity with a 4a parts car in my area which I think will close shortly. I don't want to miss out on the obvious parts while they are available.
Thanks,
Randy
65 TR4
Brosky
Randy,
I, personally, would never swap a used cam from one engine to another. Or a crank for that matter, unless some machine shop work was done to the block and the crank, as in line bore. If you are getting the cam reground and then possibly block work, it would be fine.
The other external parts are no problem, except for having the head pressure tested, cooked out and possibly resurfaced.
JMHO, other may have varying opinions.
jessebogan
Good thing to grab from a 4A parts car is the wiper switch. Same as the headlamp sw in a TR4 ,and no longer available.
Banjo
Randy, best would be to grab the whole motor as one lump. then you have everything.
I second the used cam/crank remarks.
But I think with the head, and both manifolds you've got most of the 4A advantages.
TR4nut
TR4nut
Thanks for the replies - I wanted to avoid grabbing the whole engine as it added some issues on how I was going to haul it to my place as well as explain the parts to my spouse. The manifolds I can hide under the bed..
Randy
70herald
Randy
Just get one of those antique beds with really tall legs and a skirt to hide the your stash /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
piman
Hello Randy,
"other may have varying opinions"
I would have no worries about transferring a camshaft, if it is in good condition and is better than the existing one. Make sure that the followers are good also and keep them in order, i.e that they go back onto the same lobes.
Alec
TR4nut
TR4nut
I have heard differing opinions on swapping used camshafts,but I thought the TR4 block was pretty robust in that department. I didn't think the stock TR4A cam was substantially different than a TR4 cam to warrant the change but it would be nice to have a spare handy.
But it does bring up another question I've pondered: how does one determine if the cam bearings are bad in a TR4? I've used plastigage on big end bearings to check clearance, etc, but that won't work for the cam - do you check for play with a dial indicator to determine wear on the bearings? Seems I recall that these bearings are pretty stout and rarely require replacement, but that could be wrong.
Randy
TR3driver
Great Pumpkin - R.I.P
For the front bearing (which is most likely to wear since it carries the most load), you can just try to wiggle the camshaft with the timing chain removed. Otherwise, I'd use a telescoping hole gauge and a micrometer (or calipers in a pinch). But note that you have to be very careful to get them perpendicular to the axis, or you'll get a false reading. Best practice is to take several measurements at each point, and measure multiple points within the bearing.
TR3driver
Also, if the parts are cheap, you might well be able to sell the head, crank and cam for enough to buy a performance regrind for your old cam /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Got_All_4
Swapping used cams should not be a problem if you ether use new tappets or carefully keep and match up the exact tappets from the engine that the cam came out of. I'd opt for the new ones to establish a new wear pattern. In ether case use a cam brake in lube. Your most expensive option is getting those new light weight and hard tappets that are made out of the same material the space shuttle tiles are made of. Only $50 each. You can swap in and out as many new or used cams you want.
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
P Spitfire Going up-Engine with my Herald Triumph 6
J Engine Parts Suppliers Austin Healey 6
