Front Oil Seal - BN1 box - worth it?
healeynut
Hi All -
I posted this over at the Healey List too. I'd like to get your thoughts.
Actually this is for my A90 Atlantic, which is the same thing.
Basically I was wondering if it's worth it to add a modern lip seal to the front shaft of the gearbox. It's hilly here and the box leaks out a fair amount.
I was wondering if it works... was not sure because was thinking if the box heats up then pressure builds up and pushes oil out of other areas?
not sure, would love to hear thoughts on this.
Alan
Keoke
:savewave:--Alan
Of course it is. :laugh:
Some years ago there was an article in one of the LBC Magazines describing how to modify that front housing to take a modern seal. Modified housings may be available on an exchange basis from some of our sources here in the US--Fwiw--Keoke
healeynut
healeynut
:savewave: Keoke -
Sorry I haven't been around lately, nice to see you. My work computer doesn't work with this list, and well with the two little ones running around now that they can talk, slap and tackle me, it's a bit hard to post from home too.
I can get the little front plate on the gearbox turned here in HK on a lathe for almost nothing, so just thinking about this. Someone on the list suggested putting a breather on the top of the gearbox as well...
hmmmm
Alan
I would think that there is already a breather on the trans, usually on the overdrive housing (does the A90 have an overdrive?). Otherwise, I doubt the dipstick seal__a felt drum from BN2 onwards__is airtight.
I put the original xmsn back in my BN6 last winter, and it doesn't have a seal fitted to the input shaft, so it dribbles some oil when I park the car. I recently bought a bellhousing from Quantum Mechanics (off Ebay) that was modified and had a new seal fitted; I'm pretty sure I only paid fifty bucks ($50.00USD) for it...
... another project for this winter, if I get enough of a break in the action that allows me to work on my own car.
healeynut
healeynut
Randy -
The A90 doesn't have an OD and there's no dipstick, just a bolt and a hole, so the thing is air tight if it has a front seal.
I suppose I could drill a small pin hole in the head of the filler plug bolt.
Alan
D TR2/3/3A Front Oil Seal Triumph 12
K TR2/3/3A Front hub oil seal Felt? Triumph 1
D TR4/4A Trans replacement front oil seal not same size as original Triumph 2
M_Pied_Lourd TR2/3/3A 59 TR3A Front Hub Oil Seal Triumph 2
AHS TR2/3/3A Which way does the TR3 front crankshaft oil seal face? Triumph 8
V TR2/3/3A TR3A Front Oil Seal Triumph 3
Gliderman8 Front oil seal HELP with..... Triumph 28
Gliderman8 Drip, drip, drip... NEED HELP WITH FRONT OIL SEAL Triumph 21
B TR6 TR6 Front Oil Seal Sleeve Triumph 3
toysrrus TR2/3/3A Re: TR3 "Front" Main Oil Seal: Triumph 3
bthompson 1500 front tranny oil seal?? Spridgets 14
J Gearbox front oil seal Spridgets 8
tahoe healey front oil seal Austin Healey 11
G Changing front oil seal on transmission. Triumph 14
R6MGS T-Series MGTC Front Crankshaft Oil Seal MG 5
svtmikey Front Hub oil seal question Triumph 7
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
bugedd Front suspension and oil pan Spridgets 17
TulsaFred Front engine oil leak Spridgets 33
L Oil under left front shock Austin Healey 7
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
Tim Tucker Front Engine Oil Galley Plug Triumph 10
19_again GT6 GT6 front boots grease or oil? Triumph 9
davidk Stripped threads in oil pan front saddle block Triumph 12
2wrench Re: Screw at engine front stopping oil loss Triumph 8
AUSMHLY Oil/water gauge - anyone taked the front off? Austin Healey 1
mbrooks 100 oil leak from front of engine Austin Healey 3
RobT Best way to fix the oil leak at front of block? Triumph 15
G TR5/TR250 Oil leak at front of TR250 motor Triumph 4
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
