Front Hub oil seal question
svtmikey
I am just redoing the front bearings on my GT6, and I can't figure out how to get the new oil seals back on the hubs.
I took pictures of them when I took them off, and the felt seal was facing the bearings...but I can't see how this can be right? I suspect they were installed wrong, and that's why the bearings are shot.
I think it needs to go on with the felt facing towards the vertical link, can anyone comfirm this for me....I simply can't tell from any of the manuals or the CDROM. Both pictures suck!!
Also, do I press the oil seal holder into the hub? I have already screwed up on oil seal trying to figure this out and don't want to mess up another one.
Thanks
Mikey /ubbthreads/images/graemlins/confused.gif
PeterK
You're correct. felt seal faces away from the bearing after being soaked in oil. The new felt seals may be a little too thick and need to be trimmed in 1/2 with a raxor blade in order to get correct bearing setting. PeterK
svtmikey
svtmikey
Peter,
Thanks for getting back to me...do you know if I need to press the metal ring that holds the felt seal into the hub?
Or does it just fit up against it?
Thanks
Mikey
/ubbthreads/images/graemlins/savewave.gif
PeterK
Don't really remember but I think mine just fits in the recess without need for a press.
machinemd
Assuming it to be same as the Spitfire, it needs to be tapped in until the edge of the cap is flush with the hub.
Steve
stob62
Member
On my tr6 it needed to be tapped in. Also, I found that after driving for a while the hub started to get a little loose as the felt seal compressed and wore in. I would reccommend driving it for a little while and then re-torque.
machinemd
Very good advice! I totally forgot the retorque. Mine only sat overnite and after driving only 10 miles the steering was squeamish....needed retorque big time!
K TR2/3/3A Front hub oil seal Felt? Triumph 1
M_Pied_Lourd TR2/3/3A 59 TR3A Front Hub Oil Seal Triumph 2
Carlbanan56 MGB Front hub MG 4
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
A BN7 Front Hub Stud Nuts Austin Healey 5
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
K TR2/3/3A Front Hub and Felt Seal Triumph 1
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
MikeAH100M 100 Front Hub Spacer/Distance Piece Austin Healey 2
warwick-steve Missing grease cap in front hub Austin Healey 8
warwick-steve Front hub bearing grease repacking Austin Healey 28
K TR2/3/3A Front wheel hub "felt" again? Triumph 2
K TR2/3/3A Front hub wheel bearing nut? Triumph 1
aero3113 Front Hub Inner Bearing Seal Austin Healey 7
pkmh "Bearing Outer Race" Re-installation at Passenger Front Hub Extension Austin Healey 4
Jeepster Front hub replacement. Austin Healey 34
R TR2/3/3A front hub seal options Triumph 9
Bob_Spidell Securing Front Hub Bolts Austin Healey 8
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
C Front Hub Castle Nut Austin Healey 8
B TR2/3/3A TR3 Front Hub Felt Seal questions Triumph 2
R BJ7 front hub shim question Austin Healey 18
catfood Removing front hub Austin Healey 6
RAC68 Calculating Front Hub End-Play Austin Healey 32
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
Jim_Gruber Removing front wheel bearings from hub Spridgets 6
bertl Front Hub Spacer Kit Triumph 1
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
BillD Front hub puller Spridgets 21
H front hub removal Austin Healey 37
6 front hub options... Triumph 4
S Spitfire Question on front Hub for a triumph Spitfire. Triumph 4
pkmh Dismantling BJ8 Front Hub From Caliper Disc Austin Healey 20
Willie_P TR 3/4 Front Hub Install - question Triumph 15
J Front hub mystery Austin Healey 0
britndablood To install or not to install Front hub spacer Austin Healey 8
Lon_S What hub puller tool works well for the front hub? Spridgets 2
TR4nut Front Hub Felt Seal - Old vs New Triumph 15
D Need a front hub Austin Healey 1
S Front Hub Replacement Austin Healey 7
G Front hub Spridgets 2
TonyPanchot tork settings for 1997 front hub Jaguar 1
TR3driver Front hub balance problem Triumph 17
M Front hub worn out Spridgets 6
Monark192 MGB-GT 67 GT front hub removal MG 10
drooartz Front hub/brake question Spridgets 12
Jim_Gruber Castle Nut on Front Wheel Hub Spridgets 6
B TR2/3/3A TR3 front bearing/hub advice needed Triumph 6
19_again front hub removal MG 3
