Gliderman8
I just finished driving my TR6 for the second season since complete rebuild.
At the end of season one, I stopped the leaks in the diff and the brake MC.
However, I still have an annoying leak at the front of the engine and it looks like the drip is coming right behind the crankshaft pulley so I’ve decided get this leak stopped once and for all as one of my winter projects.
When I rebuilt the engine I did install a new timing cover oil seal but unfortunately this is where I suspect it is leaking from.
So here are my questions that I’m seeking help on…
1. Is it just a matter of removing the radiator, fan, crankshaft pulley and timing cover and install another new seal?
2. What about the sleeve that slides over the front of the crankshaft… the outer diameter of the sleeve is sealed by the timing cover oil seal but won’t it still weep oil through the inner diameter where it slides onto the crankshaft?
3. Do I have to seal the inner diameter of the sleeve with RTV or similar?
Any help/advice would be appreciated from you guys who have done this.
Is there any chance I can get it stopped? …after all, it is a Triumph
Thanks for your assistance guys.
