GT6 GT6 front boots grease or oil?
19_again
starting to put the front end back together, what is recommended lubricant for the boots? I've searched the archives and seen references to overfilling them. I have also seen the Lucas red#2 grease mentioned, the 80 weight gear oil and regular bearing grease. Bentley says consult booklet that came with car, well that's not gonna happen!
Thanks, Mike
TR3driver
Great Pumpkin - R.I.P
Why not? Reprints of the owner's handbook are only $16 @ TRF; less if they're on sale.
Assuming you are talking about the steering rack boots, my GT6 manual says to use 1/2 oz of Retinax 'A' grease in them. I assume that "CV Joint grease" available at your FLAPS is an adequate substitute.
19_again
19_again
I never noticed them to tell the truth, I will order one forthwith. As far as 1/2 oz of grease is concerned, what exactly is the application procedure? How does one distribute 1/2 oz of grease throughout a boot that's 10 inches long? It seems as if there isn't enough to make a difference, should I apply the grease to the components themselves that will be protected by the boot. I have already greased the steering "hub" with the 5 pumps from the grease gun.
TR3driver
Beats me ... personally I would just grease the joint liberally and not worry about the boot, but that's not what the GT6 book says.
It is, however, what the Stag book says and I don't see any essential difference between the two (other than the Stag joint & boot being larger).
19_again
19_again
Thanks Randall, as usual it reduces down to "apply liberal amounts of common sense". Of course with stuff like steering it doesn't hurt to check. Thanks again.
svtmikey
I think when they say don't over fill them the reference in the book they are refering to pumping way too much grease into them. I have done this myself with a Pnuematic grease gun.....not paying attention and the rubber boots will actually blow out and leak grease all over the place. Not a big deal since you can remove the grease and refit the boots no problem but if you didn't notice, dirt and water would eventually get in and speed the wear of them. They just want you to know more is not necessarily better.
That's the way I read it anyway.
Mikey
DaveatMoon
Isn't the Owner's Handbook reproduced in the Bentley Manual for the GT6? It comprises the first 35 pages of my TR6 Bentley Manual.
70herald
Mikey
Ha That is quite a fun job trying to get a greasy piece of rubber back onto the rack!
TR3driver
Yes, in fact my GT6 Bentley has 3 different versions of the owner's handbook in it. But it's rather more expensive; TRF has the Bentley on sale for $70 & the regular price is $83. Perhaps it's cheaper elsewhere?
19_again
19_again
I have both bentley books (the B and the GT) and they do indeed have the manual up front. I always just go to the Bentley, I have never considered it as anything other than that. TRF lists the factory GT6 manual on CD. I picked up the MG book ($59.95) right at the Bentley office in Cambridge, but had to get a used Triumph book at Ebay for $49.00. I tried to get the GT6 Bentley book from them directly but they had none nor was production scheduled. BUT the regular price was never $83.00, Bentley's GT6 manuals have a list of $59.95 (https://www.bentleypublishers.com/triumph/gt6/).
This is a problem I have with certain suppliers who inflate prices in order to lower them for a "sale". That having been said, if Bentley doesn't have any and you need one now, then the law of supply and demand kick in. But all too often I find that quick or short term "sales" are not reduced prices at all. The supporting vendors often have lower prices.
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
T For Sale GT6 Mark II Right Front Fender - NOS Triumph Classifieds 0
JBBgt6 GT6 TRiumph GT6 Front Suspension [Spring Pan] Triumph 2
hymodyne GT6 correct front shock for 72 GT6 MK III Triumph 2
19_again GT6 GT6+ front bearings and seal Triumph 6
19_again GT6 GT6+ front shock Triumph 3
F GT6 two GT6 front suspension questions... Triumph 6
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
C GT6 GT6 fender flares Triumph 0
B GT6 trying to ID my New Car. GT6 Triumph 6
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
D GT6 9 months later. GT6+ progress Triumph 3
luke44 For Sale ‘72 GT6 MKIII For Sale Triumph Classifieds 0
LarryK GT6 Fresh purchased GT6 Triumph 11
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
idlehands Wanted GT6+ Triumph Classifieds 11
E GT6 Triumph GT6 MKIII rear hatch springs Triumph 2
B Wanted wing windows gt6 Austin Healey Classifieds 0
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
UltimateQuestion GT6 GT6 Mk3 rear wing removal Triumph 3
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
H GT6 GT6+ seat panels Triumph 2
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
R GT6 Looking to purchase GT6 Rust repair question? Triumph 4
R GT6 Triumph GT6, basic work estimates Triumph 76
glemon GT6 GT6 Getting Some Recognition Triumph 8
R For Sale Triumph GT6 3.27 rear Triumph Classifieds 2
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
brgrmyster GT6 1968 GT6 MK. 1 original emissions lines Triumph 0
brgrmyster GT6 Original GT6 Mk 1 cooling fan Triumph 24
Spritey For Sale .. or [TRADE] Early GT6 seats Triumph Classifieds 1
R Wanted Overdrive gearbox for GT6 Triumph Classifieds 0
David Townsend GT6 GT6 and Spitfire Fine Art Prints Triumph 0
Steve GT6 Spotted 2
T GT6 Opinions on what a rust free GT6 is worth Triumph 22
T GT6 GT6 and TR6 gearboxes interchange? Triumph 6
trrdster2000 GT6 Been a while on a GT6 transmission. Triumph 2
R GT6 Early Gt6 Pushrod tubes Triumph 14
David Townsend GT6 GT6 MK1 and MK2 Limited Edition Fine Art Prints Triumph 4
dklawson GT6 GT6 Clutch Failure - Where to Look First Triumph 16
anarchy99 GT6 Rear window fitment for gt6 Triumph 1
