Gearbox front oil seal
Joelb
I pulled my tranny out and found alot of oil and grease in the bell housing. I figured that the front oil seal was leaking. So, I ordered one. Now I'm cleaning up the bell housing and I don't see an old oil seal anywhere, or anywhere it would go.
According to Moss it it's application is "when fitted".
Does a 79 Midget have a front transmission oil seal?
J
Joelb
I'm just gonna bump this back up to the top in case someone who knows missed it.
fmichaels
okay ... let me take a shot at this ... i don't know of any outright oil seal in the bell housing other than the gasket for the coverplate. there is no "seal" where the shaft comes through the coverplate ... at least i have never seen one. i have wondered why there wasn't a seal but since i never saw one i figured it's just the design. i do know that the coverplate hole has sprial groves that appear to funnel the oil back into the casing. i am not sure of this but that's my thoughts on it.
J
Joelb
I know what you mean about the spiral grooves. The only reason I have even brought this up is because the seal is listed in the parts manual.
I ordered one, so when it comes in I will see if there is anywhere it could go.
fmichaels
keep us posted. my tranny is still out so if there is a seal, i want to put one in as well.
ChrisS
Don't forget you guys are talking two different transmissions here. The smooth / rib cases that bolt to the A series engine don't have a front lip seal, just the scroll seal in the front cover. Winner's Circle sells a front cover that has a lip seal in it, but this is not a factory item. I don't know what the 1500 transmissions had in them.
Morris
I bought that seal too. But I could not find anyplace to put it. I think some bell housings must be machined to accept the seal, but mine was not. I have a '79 too.
AlanT
Most Spitfire and Midget 1500 gearboxes had replaceable front oil seals but there were some scroll seal trannys all the way to end of production. The seal carrier presses out of the bellhousing if you want to change to a lip seal. The first motion shaft is the same.
Alan T
J
Joelb
Ok, cool. So I can just replace the seal carrier with the o ring and oil seal?
My current configuration has the scroll seal.
R TR6 Proper alignment of gearbox front cover plate Triumph 3
J Gearbox front cover seal Spridgets 2
K TR4/4A Gearbox front cover[Moss 848-000] torque spec? Triumph 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
F Sprite Gearbox Spridgets 5
E Gearbox problem Other Cars 0
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
AHS Side-Shift Gearbox Austin Healey 3
D Gearbox Dipstick (BT7) Austin Healey 3
K TR2/3/3A A gearbox additive? Triumph 3
C Gearbox oil British Motor Corp 3
JFS Wedge Stripped gearbox filler hole thread Triumph 3
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
W BN1 Gearbox First Motion Shaft Austin Healey 0
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
C TR2/3/3A TR3 Gearbox Problem Triumph 10
D MGA with T9 gearbox on a tow dolly MG 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
S Add ZDDP to gearbox oil? Austin Healey 29
R TR6 Gearbox slips out of 3rd gear Triumph 14
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
Lin Gearbox Oil Austin Healey 4
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
R TR6 Gearbox rebuild issues Triumph 8
S Steering Peg in Steering Gearbox Austin Healey 13
K Gearbox Throw-out pin and gasket question Austin Healey 8
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
AH67 59 xk150 gearbox Jaguar 6
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
Bayless Started adapting the datsun gearbox today Spridgets 46
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Editor_Reid General MG Gearbox Identification MG 2
Editor_Reid Gearbox Identification Austin Healey 12
W XKs Motorsport gearbox rebuild fiasco Jaguar 5
V TR2/3/3A I have a doubt about the gearbox Triumph 10
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
R Gearbox and Overdrive Oil Level Austin Healey 18
