Front Engine Oil Galley Plug
Tim Tucker
Guys,
I am working on my TR4 engine. The engine had blow by (#4 cyl) and a major leak at the front where the galley and front motor plate join. I built this motor in 1985. Had new piston/liners (86 mm), 20 under mains and 10 under pins, original cam and lifters, re-bushed rockers and new rocker shaft, new timing gears and chain. Maybe 10k miles since. I replaced the head gasket (leaking) in 1998 using Permatex Indian Head instead of the Permatex spray head gasket dressing I had used in 1985. The damage had already been done to #4 liner. This car sits a lot. Bottom line: I need to repair #4 liner and this leak on the engine front.
It appears that the oil galley plug that was installed in 1985 (block boiled) leaks. I immediately had a VERY significant leak in that area. Can the front motor plate gasket overcome this plug leaking? Did I simply fail to make a good seal on the front motor plate? Take a look at the pictures before and after cleaning. Where can these plugs be found? Google didn't really help me. I would like to start with this seal being rather leak free.
to me it looks like the top of the plug was leaking. The bottom (clean) picture shows a gap. What would you guys do?
Thanks,
Tim
lots more big pictures here: https://s902.beta.photobucket.com/user/tidentenn/library/TR4/TR4 Engine Project
TR4nut
Change the plug if you know it is leaking - that's a high pressure galley so I wouldn't count on the front plate holding back anything. Roadster factory has them, pretty cheap too. PN #PU1404, you'll get a stick of 3 for less than $5. If you don't want to go with aluminum, you can buy a set plug, don't recall the thread offhand but can probably dig out the info for you.
TR4nut
just checked out the pics, looks good! Is that a little valve recession going on with #1?
Tim Tucker
Tim Tucker
Randy,
Thanks for the reply and for letting me know the TRF part number. I'll check #1 cylinder. I'm unsure whether to lap the valves and maybe replace springs. The car ran great. The oil leak and blow prompted the tear down. Just curious: should original valve springs be declared "bad" and replace?
Tim
TR3driver
Great Pumpkin - R.I.P
IMO, if the plug was already leaking, just tap out the hole for a suitable pipe plug. As noted, no way is the paper gasket going to hold against full oil pressure.
Certainly can't hurt to check the springs for installed force, but if they are original, the chances are very good that they have sagged over the years. I'd inspect the seats and leave them alone if they are clearly good (bright shiny line all around); lap them if they are blackened or pitted anywhere. If you don't lap them, put the valves back in the same holes.
Check the liner protrusion carefully, all 4 liners, on both sides of the block. Even with new components, you may find that the protrusion is too low in places. I spent years fighting head gasket problems before I finally figured out that one side was way low on my engine. Oddly enough, that has been true on two engines in a row now; I guess the factory was a bit sloppy with the machining. As a band-aid repair, I soldered a ring of copper wire to the gasket around each cylinder, which seems to work well. Eventually of course I'll do it right, but the band-aid approach worked for over 10 years (and probably 100,000 miles) in the TR3A and was still working fine when it got wrecked.
Tim Tucker
Tim Tucker
Thanks for the great replies! I truly appreciate it.
I took the head apart today. Glad I did. The seats and valves look good, but need lapping. The guides are still good and rather tight.
The springs are another matter. The free length of the inner spring (middle spring on the exhaust valves) is ~1.79 on all 8 springs. That's .1" short of the factory spec of 1.88-1.9" (from Bently)! Looks like I'll be replacing the springs.
Any opinion on the best spring set to use? Are all of the major suppliers equal for the spring?
I added a bunch of PICs to the photobucket link, and here a pic of one of the cylinders:
Tim Tucker
Tim Tucker
I removed the front galley plug tonight. The bore it came out of is threaded. I expected to find a smooth bore that would allow the seals I got from TRF with 3 concentric rings to seal. I will try and get a photo tomorrow and measure threads per inch. I would truly appreciate any experience you guys have dealing with this plug. I have never done this task. It seems rather simple, but the threads have me baffled.
Many thanks,
Tim
TR4nut
Tim-
From my notes my understanding is that the hole is tapped for 5/8-18. The aluminum stick TRF sells is actually 3 plugs, you basically cut them apart and grind flush. Thread sealant is needed, it is not a pipe thread. If the aluminum stick looks too fragile, then you can get a socket set screw of the same thread and use instead, McMaster Carr or others will have them. Or just start with a bolt and chop the head off. Only other caution I've seen is don't have the plug too deep as it can block off a port in the galley.
Randy
Don Elliott
Since you have the head apart, why not have an engine re-build shop put in inserts to run on lead free gas? I had my shop put in 4 exhaust valve seat insert rings in 2000 and have had no issues since then driving over 66,000 miles in my 1958 TR3A. I supplied 8 new valve guides and 8 valves (in 2000, the engine had 124,000 miles on it from new). He skimmed the head and ground all the valves and seats as per spec.
Tim Tucker
Tim Tucker
Don,
The head was re-worked in 1985. I was told with unleaded OK parts. It has 26k miles on it. I plan on putting in new exhaust valves. The car ran fine. The reason for the tear down was the oil leak and the blow by from #4 cylinder (leaking head gasket (coolant into bore) and too much sitting). Plus, I just really wanted a winter project.
Did final clean on the block and head today. Installed the TRF supplied threaded oil galley plug. I don't see how this could leak:
TulsaFred Front engine oil leak Spridgets 33
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
2wrench Re: Screw at engine front stopping oil loss Triumph 8
mbrooks 100 oil leak from front of engine Austin Healey 3
R TR2/3/3A TR3A front engine seal? Triumph 3
KVH General TR Damaged Front Engine Cover Spigot Triumph 4
KVH TR4/4A Front Engine Plate Curve Triumph 4
dklawson Sorry... Urgent Request for Friend - Marina Front Engine Plate Other British Cars 2
dklawson MGB Sorry... Urgent Request for Friend - Marina Front Engine Plate MG 3
Scotsman TR2/3/3A leaking front engine plate Triumph 4
Boggsy64 MGB Transmission engine mounts and front engine mounts MG 0
mt10flyer TR2/3/3A Front Engine Plate Triumph 8
AEW TR2/3/3A TR3 engine front cover repair Triumph 10
Darrell_Walker Torque spec for front crank bolt [TR 4 cyl engine] Triumph 2
Jim_Stevens Engine front mount replacement Triumph 3
Brosky Sealing of Saddle Block in front of engine Triumph 7
2wrench I'ts about the front engine seal and RTV sealant Triumph 13
E TR6 TR6 front engine seal leak Triumph 11
Kirk_Fisher TR4/4A TR4 front fenders/engine bay Triumph 13
B Surgery on front of engine in BT7 Austin Healey 7
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
