MGB Transmission engine mounts and front engine mounts
Boggsy64
I had a terrible time getting my new front motors to bolt up to the engine. I was able to get the single bolt (stud) on the back of the mounts into the frame rail slots but not all of the bolts into the engine. It was misaligned and would not go in. I suspected the rear, or transmission, mounts as the issue causing the engine to be 1/2" too far toward the rear. Sure enough found the transmission cross member was twisted severely from a crash some time in the past. Additionally the mounts for the transmission to the cross member were put together all wrong. After getting a new cross member, and assembling the mount correctly I put it back in the car. Then jacked up the motor and wala! the front motor mounts aligned perfectly and bolts installed in minutes. Live and learn again.
KVH TR4/4A Dropping the Engine and Transmission Back onto the Mounts Triumph 22
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
AngliaGT WANTED - Cheap TD Engine/Transmission MG Classifieds 0
Bob Claffie For Sale Engine/transmission MG Classifieds 4
M MGB Early MGB engine compatible with later transmission MG 2
M For Sale BN-1 with spare engine and transmission Austin Healey Classifieds 1
S MGB early transmission vs od transmission for 3 main engine MG 5
R Remove engine/transmission advice needed Austin Healey 4
P 100M overdrive disengages on hot engine/transmission Austin Healey 9
JamesD For Sale BJ8 engine & transmission parts Austin Healey Classifieds 3
A Wanted MGC 6 cylinder straight in line engine and transmission MG Classifieds 3
R TR2/3/3A Miata Engine and transmission Triumph 12
N MGB Engine & Transmission / Gearbox MG 9
R TR2/3/3A Engine/transmission rotatio Triumph 2
T TR4/4A Remind me on pulling an engine and transmission together or seperate Triumph 11
T TR2/3/3A Can I run engine in car with no transmission? Triumph 7
M FOR SALE: 280i 2.8 v6 engine and 4 speed transmission for sale TVR 2
mcmillal TR4/4A Engine / Transmission Rebuild Triumph 1
DanLewis 1275 engine and ribcase transmission $750 [NFI] Spridgets 0
coj Healey numbering system, engine, transmission, body etc. Austin Healey 3
D Alternative engine/transmission compatibility Spridgets 72
drooartz Plans for my "free" engine and transmission MG 9
Kleykamp Transmission/engine mount removal Triumph 4
L Ribcase transmission with 948 engine Spridgets 8
M Wedge TR7 Engine, transmission and more to go Triumph 0
I Engine/transmission installation help please. Spridgets 20
G Early 100/6 engine, automatic transmission Austin Healey 2
drooartz Bolts for engine -> transmission Spridgets 3
QuickSilver OT: Value Of A 1977 MG B Engine & Transmission MG 2
L 3000 Transmission Removal, alone or with engine? Austin Healey 16
R Engine/Transmission for midget Spridgets 2
philman Wedge Removing TR8 engine+transmission Triumph 10
D 70 Midget with New Engine & $10 eBay Transmission Spridgets 5
R Stag stag engine and transmission Triumph 7
Luke_Healey Transmission leak or overfill? 1098cc engine Spridgets 9
W Weight of engine and transmission Spridgets 8
B Finally - Engine and transmission installed Spridgets 22
A Weight of Engine and Transmission Spridgets 1
Lucas63 TR4/4A TR4 Engine and Transmission Weight Triumph 5
jhorton3 Midget Engine/Transmission Bolts MG 4
RobSelina Latest on engine vibration and transmission whine Spridgets 2
R Midget engine transmission question MG 4
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
