Engine/transmission installation help please.
ichthos
I am finally ready to put the engine and transmission into my Bugeye. There is no one around to help me install these, so I will be putting them in by myself. The bonnet is currently off. My question is, is it easier to install the transmission and then the engine, or the two bolted together since I am doing this by myself? Any suggestions are greatly appreciated.
Kevin
smaceng
Kevin,
Congratulations on your progress!
As one has to say about the job of restoring a BE, it is all about the "baby steps"
See my reply to your last post.
All together, as it is a royal pain to do them separately.
Good luck, and don't pinch any fingers!
Scott in CA
I
ichthos
I read your reply, Scott. Thanks for the reply and compliment. I am pretty excited to finally get my car together, and I am trying to be patient, but I am running out of time. I know I will still have lots to do once my car is together. I have a winch that I know will support the engine and transmission. I do not have one of the levelers you showed. I am going to clear out my garage so that I have lots of room to manuever. I am also going to cover the engine bay with thick blankets. I have to move my engine out to the garage tomorrow and bolt everything together now. Any other tips?
Kevin
JPSmit
I reinstalled my engine with the car up on jackstands - gave a lot more "under room" as well as no chance of it rolling and not so far to bend over.
smaceng
Hard to put the engine and trans in with just one person without the leveler. I would highly recommend it. I got mine at Harbor Freight. Also put the slave cylinder on with the pipes beforehand. Don't forget to insert the drive shaft in the trans as you are putting it home into tunnel.
Scott in CA
TexasSprite
I installed the engine/transmission as a unit. Radiator off, of course. I did mount the drive shaft on the transmission before I installed it. I did not have a leveler, but found drive train for the BE to be light enough to easily tilt and slide it in place by myself. There is a trick about the motor mounts which I can't exactly remember, but it has something to do with leaving one of them off of the engine and bolting it up after everything is in place.
Billm
Motor mounts-
Mount the one by the steering column to the car first, the one for the other side to the engine and that's it. If you do it the other way then the steering column prevents the mount from dropping all of the way down.
BillM
G
Scott in CA
I prefer pinching buttocks myself. (not my own)
This is a good idea as my hoist won't fit under the car enough to get the motor in. A leveler makes things so much easier too.
JPSmit
was that you???!!!! :madder:
mightymidget
I'm gonna third that.
Makes the job so much easier, plus a biggie is like it was said not needed to bend over so much while you are twisting motor.
I put my motor /tranny in together (midget) with out a leveler by myself. it wasn't that big of a deal. actually don't belive I would have used it if I had one.
I just took my right hand and held end of tranny down as I let the motor down with my left hand. stoped. push picker in do motor moved back in tunnel. then did the same again
JPSmit
Oh, and we put towels and blankets on the edges and new paint
I
ichthos
Thanks for all the tips, everyone. If everything goes right, I should have the engine in this weekend. I will post pics once I am done.
Kevin
c5racer
Member
Anyone have a part number for the engine leveler at HF? The search engine is worthless or I can't figure out the "key word"
I
ichthos
I ended up having to go to Harbor Freight to find what I needed - well actually my wife did. I couldn't seem to find anything on line at their site. The model she bought was #5402. The cost was $40. It is rated for 2,000 pounds. They also had a cheaper one on sale for $25 that was rated for 1,500 pounds. I have the engine suspended up in the air at the moment, and the turn screw turns easily. One of the problems I have heard about cheaper levelers was that the turn screw does not turn well when there is weight on it. Maybe someone who bought the cheaper leveler can give you some feedback. With sparse descriptions for levelers on line in general, it was difficult for me to figure out why some are more expensive than others. Hope that helps.
Kevin
jlaird
And for 50 bucks how could a person go wrong.
c5racer
Member
Picked one up at HF today #5402 cost was $40. It looks a little safer/solid than the $25 one.
Thanks!
jlaird
er correction. For $40 bucks how could a person go wrong?
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
AngliaGT WANTED - Cheap TD Engine/Transmission MG Classifieds 0
Bob Claffie For Sale Engine/transmission MG Classifieds 4
M MGB Early MGB engine compatible with later transmission MG 2
M For Sale BN-1 with spare engine and transmission Austin Healey Classifieds 1
S MGB early transmission vs od transmission for 3 main engine MG 5
R Remove engine/transmission advice needed Austin Healey 4
P 100M overdrive disengages on hot engine/transmission Austin Healey 9
JamesD For Sale BJ8 engine & transmission parts Austin Healey Classifieds 3
A Wanted MGC 6 cylinder straight in line engine and transmission MG Classifieds 3
R TR2/3/3A Miata Engine and transmission Triumph 12
N MGB Engine & Transmission / Gearbox MG 9
R TR2/3/3A Engine/transmission rotatio Triumph 2
T TR4/4A Remind me on pulling an engine and transmission together or seperate Triumph 11
KVH TR4/4A Dropping the Engine and Transmission Back onto the Mounts Triumph 22
T TR2/3/3A Can I run engine in car with no transmission? Triumph 7
M FOR SALE: 280i 2.8 v6 engine and 4 speed transmission for sale TVR 2
mcmillal TR4/4A Engine / Transmission Rebuild Triumph 1
DanLewis 1275 engine and ribcase transmission $750 [NFI] Spridgets 0
coj Healey numbering system, engine, transmission, body etc. Austin Healey 3
Boggsy64 MGB Transmission engine mounts and front engine mounts MG 0
D Alternative engine/transmission compatibility Spridgets 72
drooartz Plans for my "free" engine and transmission MG 9
Kleykamp Transmission/engine mount removal Triumph 4
L Ribcase transmission with 948 engine Spridgets 8
M Wedge TR7 Engine, transmission and more to go Triumph 0
G Early 100/6 engine, automatic transmission Austin Healey 2
drooartz Bolts for engine -> transmission Spridgets 3
QuickSilver OT: Value Of A 1977 MG B Engine & Transmission MG 2
L 3000 Transmission Removal, alone or with engine? Austin Healey 16
R Engine/Transmission for midget Spridgets 2
philman Wedge Removing TR8 engine+transmission Triumph 10
D 70 Midget with New Engine & $10 eBay Transmission Spridgets 5
R Stag stag engine and transmission Triumph 7
Luke_Healey Transmission leak or overfill? 1098cc engine Spridgets 9
W Weight of engine and transmission Spridgets 8
B Finally - Engine and transmission installed Spridgets 22
A Weight of Engine and Transmission Spridgets 1
Lucas63 TR4/4A TR4 Engine and Transmission Weight Triumph 5
jhorton3 Midget Engine/Transmission Bolts MG 4
RobSelina Latest on engine vibration and transmission whine Spridgets 2
R Midget engine transmission question MG 4
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
