Plans for my "free" engine and transmission
drooartz
So I've got this free B Engine, a 18V from '76 or so with a CAM-1106 head. Originally I was thinking this would either be the basis for an eventual performance build or a swap in so I could rebuild my current (and original) engine when the time comes.
Now, however, I'm thinking that I'm going to use this to learn more about engines. So I'll take Hap's article about how to tear down an engine and get some practice. Go through all the steps to see what condition this engine is in. It doesn't owe me anything, so if I break something I'm not to fussed.
If everything checked out properly, I'd plan to put it all back together (cheap refresh) and have it as a spare. Otherwise I can send the bits off to recycling.
Figure I'll do the same with the transmission, never been inside one of those before.
Flash_Harry
Sounds like a good plan, Drew. I've got the original engine from my '74 GT, just sitting in the garage. Might be good to do what you plan, and have a good spare, just in case.
The last engine I took apart was a '30-something Chevy 6-cylinder, given to us by a loon we knew. A friend and I - both of us 12 - took it almost all the way down, put it back together, and danged if it didn't run!
Harry
Mickey Richaud
Harry
And the gauntlet is thrown! :devilgrin:
You gotta start somewhere, Drew, and your plan sounds like a good one. I've done several engines, but never delved into a transmission. Maybe one day...
drooartz
drooartz
If it was an OD transmission, I'd do something more serious with it, but a non OD 4-sync MGB transmissions has very little value. Hopefully a good learning tool, though.
I've never rebuilt an engine -- closest was when I tore down the 1275 for the Tunebug before sending it to Hap. He did all the hard work, I just disassembled. Would be nice to build something that ran, though, to have around as a spare.
Sarastro
I did the same thing a few years ago with a 1275 Midget engine. I had planned to put it into my Bugeye, but after getting it rebuilt, I foresaw a long process of getting it sorted out. The 948 was running well, so I decided against the swap and eventually sold the 1275.
I learned a lot, and I sold it for what I had put into it. Can't do much better than that.
drooartz
drooartz
I figure that the worst that can happen is I'll learn a bunch and have a heavy pile of scrap metal to dispose of. Best case I get a spare running engine as well.
Platinum
Good plan! But I'd say keep goin' on it after tear-down. Make it a viable spare. The "mule" as it were... if you have it complete and stowed, the one in the car can be rebuilt as YOU decide, swapped out at convenience instead of VOR (Vehicle Off Road) for a year.
drooartz
drooartz
That's what I'm thinking now, Doc. I do eventually want to rebuild the one in the car, as it's the original block. Some sort of nice street/performance build. Having this one ready to go would be the way to do it -- weekend of swap and off we go.
Should be a fun project, I've never rebuilt an engine before.
Drew I want lots of folks thur this process each year, with my engine rebuilt kits, the article is a good way to do the tear down, it's about learning as much as you can from the tear down.
I'm working on the next article now, very slowly :smile:, it will probably appear in the Spring Moss Motoring magazine, it will cover cleaning and prep the biggest and hardest job of this project) , machine shop phase, and assembly.
The biggest issue I see people run into is a very minumal approach, they want to keep things on tight budget, hey we all do :smile: They get it in thier minds, they can "look" at things and not measure, I always tell them, " the human eye ,while a very useful tool is not precision measuring tool, and a engine tells us what it needs, not the other way around". I think the guys who get themselves in the most trouble are the ones who think the crank journals and cylinder can stay standard, because they "looked good", these folks normally open bearing and piston boxes, handle these parts, then discover thye can't use them, and can't return them , so they end up spending more money, trying to save money. The first part of the machine shop phase is the measuring part, and at that point, you then will know what sizes you need, and save alot of money, and frustration.
When you get ready Drew, give me a shout. You'll need to buy a few tools for this.
drooartz
drooartz
I'm looking forward to learning how to do the measuring, Hap -- and to the new tools I'll need. The only engine I've ever been inside of was the 1275 for the Tunebug, and that was just disassembly for shipping purposes. With this one I really want to learn how this process is done. All this engine cost was the gas to go pick it up, so it doesn't owe me anything. Would be nice to have it as a working spare, though.
When it comes time to do the real build up for my B, I'll want to use the engine that's in the car now. It's the original 18GG block that came with the car when it was new, and it has a non-smog 12H2709 head on it now. I like the idea of using the original pieces for the long term build, but it would be nice to have something to swap in while I'm doing the major build up.
I will definitely give you a call when I get serious about going through this one. May try and at least get the engine and transmission split and the engine on a stand this weekend. Just has to get a bit warmer out there -- it's 3*f at my house this morning. Brrrrrr :cold:
AngliaGT MGB-GT The Best Laid Plans....... MG 3
M TR6 Updates and plans! Triumph 2
Hamish Racing General TR Some New Bling MaXpeedingRods review and plans Triumph 5
A Engine stand rotisserie plans Austin Healey 12
R I Need Rotisserie plans for midget Spridgets 18
S Dolly plans Austin Healey 5
HerronScott Garage plans? Restoration & Tools 41
Aeroken Funny how plans change... Triumph 1
Tabcon Performance upgrade plans and an SU question. Triumph 8
Stewart So what are your weekend plans? MG 18
kcbugeye1275 Plans for this next yr. Spridgets 6
tony barnhill Jack Laird - What're Your weekend Plans? Spridgets 4
cdsmith Best laid plans... Spridgets 8
drooartz Start of my engine plans Spridgets 0
drooartz Tunebug plans, written down Spridgets 16
ronzet Best laid plans of mice and men... Steinbeck... MG 29
Baz Plans for the Midget Spridgets 8
V Re-wiring my whole car this week/Car plans Triumph 10
B Garage plans Restoration & Tools 24
Bret Short & Long term plans MG 12
J Jaguar postpones plans to develop F-Type roadster Jaguar 0
S For Sale FREE HARDTOP.. top is in Palm Springs, Cal. Call Bob ,562 400 5983 MG Classifieds 1
jfarris For Sale FREE 83mm flex hone - item claimed Triumph Classifieds 1
M T-Series TD/TF Steering Free Play Question MG 6
Hangtown Healey BN4 Front Springs Free Length Austin Healey 3
BritFullHouse For Sale 56 MGA engine parts for free!! MG Classifieds 2
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 6
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
TomMull Free Triumph Herald Headboard Triumph Classifieds 0
JimLaney For Sale 2 MK IIIs :Free to good Home Spridgets Classified 1
Joe Schlosser Wire wheel Parts Free to good home Spridgets 0
69MGC MGB MGB Driver Magazines FREE MG 4
Tybalt TR6 Free TR6? Triumph 3
L General TR Ethanol free gas Triumph 34
pbraun For Sale Free 948 and smooth case Spridgets Classified 0
E For Sale 1955 Austin Healey 100 /4 rust free project car Austin Healey Classifieds 3
FredApplerot For Sale Free: Midget sun visors to fit 1977-80 Spridgets Classified 1
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
Jim_Gruber Free Spridget Windscreen available - Dayton OH Spridgets 3
Rut TR4/4A Rust free TRs Triumph 4
bugedd Free header Spridgets 0
G For Sale Free - 4 Vega GT Wheels Spridgets Classified 0
Jim_Stevens For Sale TR3 Free frame Triumph Classifieds 0
Joe Reed General MG MG Driver back issues....FREE! Anyone want them? MG 4
AngliaGT MGB Two FREE MG B's - Hoopa,CA MG 4
T For Sale Free tr3 transmission radiator and generator Triumph Classifieds 2
CJD TR2/3/3A Free Frame Triumph 4
