TR2/3/3A Can I run engine in car with no transmission?
TuffTR250
Can I safely run the engine in my TR3 without the transmission installed? If yes, how would I support the back end of the engine? I would be leery of just putting a block under the sump since that could bend the sump due to engine vibration while running.
Regards,
Bob
Running an engine without a transmission is safe, engines are run on stands for testing or break in all the time. You'd want to have the flywheel in place, both for the starter if being used and for providing mass to smooth out the run. As for supporting the engine, you might look into either bracing it to the firewall or making a U shape from angle iron that can be attached to a couple of the sump bolts on either side to carry the load to the ground. Of course, the choice would be influenced by how mobile the car needs to be during this period.
T
TuffTR250
Thanks for the responses! I like the idea of making a brace out of angle iron to support the back end of the engine. I'll open my garage door when I run the car. I usually also put a big fan in the door way behind the car to blow the exhaust fumes out.
Regards,
Bob
sp53
My concern would be the starter breaking the casting off the block. I think the casting would be very weak at the starter hole if the bell housing of the transmission is not bolted together with it. Heck that casting sticks out several inches. I have always been afraid I would break it just moving the engine around. I think a starter hooked only to that cantilevered piece of casting might snap the casting right off.
T
TuffTR250
Thanks ps53! I agree that could be a problem. Does anyone have any experience with using the starter without the transmission bell housing attached?
Regards,
Bob
It's tougher than you think. I never seen one broken off and I've have a lot of those engines (50+). I have cranked several without the trans as well
marv
T
TuffTR250
Thanks Marv! That's good news! Have you ran a TR3/4 engine for any length of time without transmission, how did you support the back end?
Wow 50+ engines!
Regards,
Bob
S TR2/3/3A problems getting the engine to run correct Triumph 21
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
L BJ-8 Engine run-on Austin Healey 21
bighealeysource TR6 TR6 will not start back up after being run for a while and engine warm Triumph 15
Tinkerman TR2/3/3A TR 3A engine run in specs. Triumph 4
TulsaFred Engine test run stand Spridgets 10
J Engine run-on after stopping. Austin Healey 14
chicken What temperature should the engine run at Austin Healey 4
A my engine run Austin Healey 2
N So what is the Triumph Forum Run-In for new engine Triumph 9
V Myth: run engine at 2200 rpm for 20 to 30 min Triumph 10
Tinkerman TR2/3/3A How to build an engine run in stand for 60 TR3 Triumph 9
M Cooling fans will not run - engine very hot. Jaguar 4
D what oil to use for engine run-in??? Restoration & Tools 1
JPSmit Tonight's ice cream run Spotted 3
shadowfever Shake down run Spridgets 2
L MGB 1977 MGB will only run on full choke MG 53
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
S TR6 Anti Run-On Valve question. Triumph 4
A MGB-GT Video- Three minute run through Smugglers Notch in Vermont. MG 4
A Spitfire Video- Three minute run through Smugglers Notch in Vermont. Triumph 4
D Spitfire 20-50 oil says run in car manuel Triumph 6
DrEntropy MGB Shakedown run MG 6
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
S My 68 sprite hit and run Spridgets 10
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
steveg Anti-run on solution Austin Healey 10
D Been waiting for a hot day run Austin Healey 4
B MGB New Dual SU's and Run-On MG 3
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
Marvin Gruber TR4/4A Almost a burnt run Triumph 12
PeterK Spitfire OK then but will it run Triumph 6
Sopwith_Camel 95 xj r cheap should i run away screaming? Jaguar 2
RickB MGB Taking a run north this weekend, Bellingham & Blaine MG 4
P TR6 Won't start after 10-mile run Triumph 21
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
1 TR6 Tr6 needs choke to run good Triumph 11
H Rad bulkhead plates production run? Austin Healey 8
M_Pied_Lourd TR4/4A TR4 fuel line run. Triumph 5
RichBall Parts Run Spridgets 3
John_Mc General TR The secret to a 12 Parsec Kessel Run Triumph 1
J Found an E Type in a Barn. Bought it. Let's Make it Run Jaguar 15
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
D LSR test run Racing 2
L What is the rustiest, most run down Healey you have ever seen? Austin Healey 56
KVH TR4/4A Pre Ignition Run On Triumph 2
angelfj1 General TR last run with the lady Triumph 19
S TR2/3/3A Ignition Run-On Triumph 5
D TR6 Anti run-on valve Triumph 3
Gliderman8 TR6 Starter energizes when in RUN Position...... Triumph 17
