TR2/3/3A Ignition Run-On
smdichter
Member
Carter low pressure electric fuel pump, Pertronix electronic ignition, carbs seem to be properly set, idle at 800. When I turn the ignition off, the engine keeps running a little, bumpity-bumpity-bumpity - brrrr-thud. If I disconnect the battery, same thing. If I turn the ignition back on while this is happening, it fires back up completely.
I think this is called "run-on." How do I stop it?
Also a general question about Forum searches. If I type in run on, it gives me "run, on" and rejects the search request because it will return too many items. Is there a way to string words together? Do you use quotes? Some other method?
Thanks.
martx-5
Put you foot on the brake, leave it in gear and dump the clutch as you turn off the ignition.
Mine will do it sometimes as I really can't get it to idle much below about 900 rpm with the cam and all else that I did to the engine. Therefore, I just got into the habit of dumping the clutch. If timed right, you can't even tell it was done.
Also, I pretty sure the search engine will accept quotes and + signs between the words.
TR3driver
Great Pumpkin - R.I.P
If you can get the idle down to the specified 500 rpm, the runon will likely disappear. I can't, though, so I do the same as Art. With a little practice, it becomes habit and you can do it so smoothly you won't know if the engine wanted to runon or not. But be sure to keep your other foot on the brake, just in case it tries to go another turn.
sp53
What do the plugs look like? If they have carbon or oil deposits the motor will diesel on also. Sometimes when the distributor does not operate correctly deposits will build up also causing the same problem. When I shut my tr3 off, it stops right away.
croz
I had the same problem for a while. Try running a tank or two of high octane fuel. This should run hot enough to burn out the carbon deposits that are causing your run on. If the problem comes back on regular, make the switch to premium. Worked for me.
daive
My 1960 TR3a has been running on since I bought it 6 months ago I have tried cooler plugs, lower idle,moving distributor?? both ways,high test gas, even driving at
4000 rpm for 30 minutes (to remove carbon) no change.The car runs extremely well plenty of power next move remove head and check for hot spots ? meanwhile
stalling out works for me
Dave.
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
KVH TR4/4A Pre Ignition Run On Triumph 2
Jim_Newman MSD Ignition and weird run-on Austin Healey 4
T lotus excel ignition - can i run a crane hi-6 ? Lotus 0
E '79B Cooling Fans run [blink] after ignition off MG 6
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 7
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
Cappy Ignition Warning Light Austin Healey 6
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
S Ignition advance weights - how to lube? Austin Healey 5
K TR2/3/3A Ignition Timing? Triumph 11
