Tinkerman
Getting to the point that I need to "run in" the engine. Would some info on the best way to do that. RPM's, time and so forth. The engine is essentially a new engine. Machined by a local shop, rebuilt by me. It has stock oversized pistons. The head has standard valves, delrin spacers and was ported and relieved and mildly shaved. The engine has a mild street cam in it.
Compression is as follows : Cylinders 1 through 3 are 170 psi and # 4 is 165 psi.
My questions are: run in at what rpm, for how long and any other tips and suggestions you might have.
Your thoughts greatly appreciated!
Thanks, Tinkerman
Thanks, Tinkerman
