Spitfire OK then but will it run
dklawson
And yet... as of 6:00 p.m. on 6/21/17 there are SEVEN bidders. There is not much Spitfire left on that car.
How much Bondo do you think they used to sculpt that transition to the hood bulge?
Sarastro
About as attractive as dog turds squashed into a rug in July.
I always wonder why people with no taste think they can improve on the original. They never succeed. Never.
TomMull
I dunno. The hood bulge does look a bit scary but other features appear to be well done. Not my cup of tea but at $1500 not much in it's class. Interesting car if nothing else.
Tom
Deleted member 8987
I see the radiator in the boot...3-4 inches between it at the taillights...those rear louvers must be for radiator...but what is the screen looking thingamabob where the license would fit?
Put a low clearance EFI on top of that lump and you might get the bonnet extrusion to disappear.
TomMull
Perhaps if the air flow is front to back the screen might discharge heated air. And with the EFI you might get an increase in power too.
Tom
JPSmit Tonight's ice cream run Spotted 3
shadowfever Shake down run Spridgets 2
L MGB 1977 MGB will only run on full choke MG 53
S TR2/3/3A problems getting the engine to run correct Triumph 21
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
S TR6 Anti Run-On Valve question. Triumph 4
A MGB-GT Video- Three minute run through Smugglers Notch in Vermont. MG 4
A Spitfire Video- Three minute run through Smugglers Notch in Vermont. Triumph 4
D Spitfire 20-50 oil says run in car manuel Triumph 6
DrEntropy MGB Shakedown run MG 6
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
S My 68 sprite hit and run Spridgets 10
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
steveg Anti-run on solution Austin Healey 10
D Been waiting for a hot day run Austin Healey 4
B MGB New Dual SU's and Run-On MG 3
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
Marvin Gruber TR4/4A Almost a burnt run Triumph 12
Sopwith_Camel 95 xj r cheap should i run away screaming? Jaguar 2
RickB MGB Taking a run north this weekend, Bellingham & Blaine MG 4
P TR6 Won't start after 10-mile run Triumph 21
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
1 TR6 Tr6 needs choke to run good Triumph 11
H Rad bulkhead plates production run? Austin Healey 8
M_Pied_Lourd TR4/4A TR4 fuel line run. Triumph 5
L BJ-8 Engine run-on Austin Healey 21
RichBall Parts Run Spridgets 3
John_Mc General TR The secret to a 12 Parsec Kessel Run Triumph 1
T TR2/3/3A Can I run engine in car with no transmission? Triumph 7
J Found an E Type in a Barn. Bought it. Let's Make it Run Jaguar 15
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
D LSR test run Racing 2
L What is the rustiest, most run down Healey you have ever seen? Austin Healey 56
KVH TR4/4A Pre Ignition Run On Triumph 2
bighealeysource TR6 TR6 will not start back up after being run for a while and engine warm Triumph 15
angelfj1 General TR last run with the lady Triumph 19
S TR2/3/3A Ignition Run-On Triumph 5
D TR6 Anti run-on valve Triumph 3
Gliderman8 TR6 Starter energizes when in RUN Position...... Triumph 17
Keith_M Breakfast run Austin Healey 3
R reason for it said 1500 has cooling [run to hot] problems? Spridgets 20
B Strombergs Run Rich Triumph 12
NutmegCT TR2/3/3A low idle after a fast run - TR3 Triumph 4
Tinkerman TR2/3/3A TR 3A engine run in specs. Triumph 4
Tinkerman TR2/3/3A 60 TR3A Will not run above idle speed, help! Triumph 11
J TR4/4A TR4 won't run correctly Triumph 13
G Run on DIeseling RESOLVED Triumph 7
M TR4/4A 67 TR4A hasn't run for 10 yrs+... suggestions? Triumph 11
B TR2/3/3A Rad installed = TR3A no run Triumph 8
