TR2/3/3A Exhaust manifold clean up.
DavidApp
Looking at my manifold I was thinking of sand blasting it as it is kind of rusty.
Should I paint it with manifold paint? What colour would be correct if I were to paint it?
David
charleyf
David,
I sand blasted mine and then painted it with a silver high temp ( manifold) paint.
tThe TRA RESTORATION STANDARDS says the exhaust system on the Original cars were painted black but later changed the color to dull silver. Apparently this was done to keep them from rusting during preassembly storage.
Charley
Dash
Sorry it's a little fuzzy but this is what mine looks like after a using a wire wheel on the grinder then spray cleaned with carb cleaner (it's what I already had on hand) then a good rinse. Used rubber gloves to handle after that and sprayed a couple light coats of VHT flame proof primer followed by a couple light coats and one medium coat of VHT flame proof sp998 they call cast iron grey.. had a gas oven in the shed I hooked up a 20 gal propane tank to and cooked it per instructions on the can. Matches the intakes pretty well..will it hold up..who knows...
M_Pied_Lourd
Rut
David,
I took a different approach and soaked mine in undiluted SuperClean from Walmart to degrease and remove old paint followed by a soak in Evaporust which removed all the rust. I used VHT cast aluminum ceramic paint and baked it per the directions on the can, but you can just run the engine and get the same result. This one is on my MGB and it's 3 years old and looks the same as when I first painted it.
Rut
DavidApp
Thank you Dash, Tush and Rut for the info and photos. They look good.
Wanted to make sure that I was headed in the right direction with the manifold. Have to visit A.Z. when I get back home. Working out of town for a few weeks to get TR money.
David
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
Zitch For Sale TR-4A exhaust manifold Triumph Classifieds 0
AUSMHLY Exhaust Manifold Flange Stud Austin Healey 13
BLong63AH Removal of Intake and Exhaust manifold. Austin Healey BJ7 Austin Healey 24
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
B Gasket Sealer on Intake/Exhaust Manifold Gasket. Austin Healey 7
K Wanted 100-6 exhaust manifold for two port head Austin Healey Classifieds 0
T TR6 Refinishing Exhaust Manifold Triumph 4
T TR6 Refinishing Exhaust Manifold Triumph 6
D TR2/3/3A Exhaust pipe flange stuck to manifold Triumph 5
RJS TR4/4A Exhaust Manifold - Most Durable Finish? Triumph 4
D TR4/4A wobbly exhaust manifold studs Triumph 17
M 1275 Exhaust Manifold Needed Spridgets 6
Csarneson Exhaust Manifold finish? Austin Healey 18
C TR2/3/3A Intake/Exhaust Manifold Replacement Triumph 11
K TR2/3/3A Broken exhaust manifold TR3b Triumph 13
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
S TR4/4A exhaust manifold gasket also later tr3 Triumph 2
Martinld123 Oil Seeping Out One Exhaust Manifold Bolt Austin Healey 8
S TR4/4A Exhaust manifold missing stud Triumph 8
Got_All_4 General TR Coating a exhaust manifold Triumph 12
H The heat shield for the Longbridge between the exhaust manifold and carbs Austin Healey 1
trglory TR6 Exhaust manifold plugs Triumph 4
S TR2/3/3A exhaust manifold with rusted and broke studs Triumph 5
3798j General TR Ceramic Coated Exhaust Manifold Triumph 8
J New tube exhaust and intake manifold Austin Healey 15
J TR2/3/3A leak proofing intake/exhaust manifold Triumph 20
af3683 TR2/3/3A TR3B Exhaust Manifold Gaskets Triumph 15
G TR4/4A tr4a exhaust manifold Triumph 15
D wtb 948 exhaust manifold Spridgets 3
B TR6 Anyone know where to get a decent Exhaust Manifold for 72 TR6 [dual] Triumph 2
B TR6 TR6 decision on header/manifold/exhaust Triumph 4
angelfj1 TR 4-cyl exhaust manifold to cylinder head nuts Triumph 4
J Bling! New ceramic coating on exhaust manifold Spridgets 8
M Exhaust leak at manifold to pipe bracket Spridgets 3
J Fuel leak onto exhaust manifold - Help! Austin Healey 3
J TR2/3/3A TR3 exhaust manifold stud thread size? Triumph 3
TulsaFred 1275 exhaust manifold ? Spridgets 1
S TR6 71 tr6 exhaust manifold options Triumph 7
doughairfield TR4/4A TR4a exhaust manifold on a TR4? Triumph 6
HealeyDave Exhaust Manifold Stud Removal Austin Healey 18
