TR2/3/3A TR3B Exhaust Manifold Gaskets
af3683
I brought my TR3B to my mechanic to replace the entire exhaust system. While removing the exhaust pipe, 2 of the 3 nuts broke and the end of the exhaust pipe is still stuck on the end of the exhaust manifold. He has tried heat and various lubricants but it still won't budge. So now he has to remove the exhaust manifold. Would someone be kind enough to tell me exactly which manifold / carb gaskets I need to replace. I looked on the TRF and Moss web sites but I am really confused. Thanks so much for your help. Art
TR3driver
Great Pumpkin - R.I.P
Here's the TRF/factory numbers:
(2) 113122 gasket, manifold to head
(1) 106958 gasket, exhaust manifold to head pipe
I usually find it possible to leave the carbs attached to the intake manifold (both manifolds must be removed together). But if they have to come off, you'll need
(4) 112867
Usually, the insulators can be reused. But if not,
(2) 112866
As long as you're ordering, might as well get the new studs. Sounds like 2 of the 3 are already ruined, and I'm guessing the third one is in bad shape.
(3) 101442
As a side note (your mechanic probably already knows this), I find it very helpful to coat the studs with copper-based anti-seize, every time I have the nuts off. It works really well at ensuring the nuts will come off next time with a minimum of fuss. I've tried brass nuts and so on, but ordinary steel nuts plus the anti-seize work the best of anything I've tried.
PS, be sure he uses new split lockwashers on the nuts holding the manifolds to the heads. The heat seems to make them lose their spring, which lets the nuts work loose later on. I also find it helps to use a heavy flat washer (aka setup washer) on the outermost studs (the ones without the bridge pieces) in addition to the split washer.
af3683
af3683
Randall, thanks so much. I guess I might as well get the #WL208 Washers from TRF as well. He did remove the carbs for better access, but it didn't seem to help. Do you know if it is common for these studs to break off? I don't think the head pipe is original, but that doesn't mean it hasn't been on there for many years. I wasn't expecting this be such a big job. Art
TR3driver
Quite common, I'm afraid; they lead a really hard life down there. I twisted them off just about every time before I discovered anti-seize. Haven't had one twist off since then, but they are still frequently bad enough to be worth replacing.
I've had the same problem with other old cars as well, it's not just a Triumph thing.
CJD
Yep! 2/3 is my usual batting average.
The routine usually goes: Twist them off, remove the manifold, ground the end of the broken stud flat, drill the center of the stud, try to use an extractor (which never works), re-drill the stud completely out, run a tap through the manifold.
After a while working on old cars, you expect to go through the routine, and feel REALLY excited if you don't!
af3683
af3683
Thank you all. This is probably a dumb question, but I assume that the 2 manifold gaskets do NOT require any cement. Also, why are 2 required? Thanks. Art
Geo Hahn
I have never used any sealant on those gaskets.
You need two as each gasket is for a pair of cylinders, i.e. one for 1&2 and another for 3&4.
TRTEL
The copper anti seize is a good idea. If you can't find that molybdenum disulfide base works almost as well. I've had luck with higher grade stainless nuts. You can usually find them at nut and bolt specialists or aircraft suppliers close to airfields.
mgedit
My car had no split washers at all when I got it. I plan to use new ones now. Question ... why not use setup washers on all the studs (that is the ones with the bridge pieces too)? Was concerned that lock washers would some how interfer with proper operation of bridge pieces, but perhaps flat washer might as well. Just curious as to how the manifolds should be reattached and what combination of nuts and washers works best. Thanks for the help. Cheers, Mike
vivdownunder
The bridge pieces taper so the front flat is about the same diameter as a split washer. A flat washer would overhang and look out of place.
I too have found a flat and split washer works best at the outer ends of the exhaust manifold (in my case Triumphtune extractors). Adding a flat washer tends to hold the flange tighter against the head and lessen the risk of gasket leakage.
Viv
Geo Hahn
On the TR3A I use longer nuts, I think these are easier to work with especially under the manifold as they are not as deep a reach for the socket & u-joint I usually use.
I have some that are steel but have only been able to find them in brass at the local FLAPS.
On the TR4 I am using brass nuts as an experiment.
BTW I find that I have to get the bridge piece on the lower studs before the manifold is up against the head. If I wait until the manifold is fully home then there is not enough room between the end of the stud and the manifold to get the bridge piece on there -- but that may just be a function of stud length on my head.
The key to this exercise is to pull the head off every year or so -- that way everything comes apart quite readily and the procedure remains fresh in your mind.
TR3driver
Original setup was tall steel nuts and spring washers on all 8 studs. The tall steel nuts are available from TRF under PN 56675. As Geo noted, they are easier to get a socket or wrench on, even if they don't help keep things tight.
I don't know of any reason why not, they just don't seem to be needed.
Well, obviously I think my setup works best, but your mileage may vary :smile:
Years ago, I had trouble with the exhaust gaskets blowing. (Don't recall offhand if that was with a stock manifold or cheap tubular header from JCW. Probably the latter.) I got in the habit of checking the nuts at every oil change, and they frequently moved by a half flat or more. Replacing the lock washers helped, but the outer nuts still worked loose over time. So I added the heavy flat washers there, and the problem seemed to go away. I haven't had a gasket blow for over 30 years (and don't even bother to check the nuts any more).
My theory is that the exhaust manifold flange winds up expanding faster than the head does, every time it gets hot (meaning every time you start the engine). So it has to move a little bit against the head. I'm guessing that it winds up moving a little bit against the nut & washer as well (instead of just bending the stud). Since the lockwasher tends to dig in, the setup washer gives it a joint that can move. I could be way off base, but it worked for me.
K TR2/3/3A Broken exhaust manifold TR3b Triumph 13
B TR2/3/3A tr3b center exhaust hanger Triumph 3
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
AngliaGT TR2/3/3A Value of a One Owner,Excellent Condition TR3B ? Triumph 12
glemon TR2/3/3A TR3B Triumph 10
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
P TR2/3/3A TR3B SU carbs Triumph 10
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
P TR3B Coil Issue? Triumph 7
P TR2/3/3A TR3B Panel Light Switch Triumph 20
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
af3683 TR2/3/3A TR3B Oil Drain Plug Triumph 10
J TR2/3/3A TR3b Tyres Triumph 6
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
W TR2/3/3A TR3B ‘TCF’ on BAT Triumph 10
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
tr3guy TR2/3/3A Late TR3A, TR3B windshield assemply Triumph 5
K TR2/3/3A Windshield stanchions on a TR3b - guide plates?? Triumph 13
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
M TR2/3/3A After Market Oil Filter - TR3B Triumph 8
M TR2/3/3A Technical Assistance Needed - TR3B Carb Adjustment Triumph 5
D TR2/3/3A Best TR3B seats - repair or replacement? Triumph 11
D TR2/3/3A TR3B Tire sizes? Triumph 10
S TR2/3/3A 155/15 Vredestein Sprint Classic on a 4.5" Wire Wheel as TR3B Spare? Triumph 6
J Restoring a '62 TR3B Restoration & Tools 2
M TR2/3/3A TR3B Door Cables Triumph 5
M Door Cables - 62 TR3B Spridgets 1
B TR2/3/3A Are these seat slides for a TR3B? how do you paint them? Triumph 8
B TR2/3/3A carpet snap questions tr3B Triumph 1
B TR2/3/3A TR3b lower door seal question Triumph 3
B TR2/3/3A steering box seal replacement TR3B Triumph 4
C General TR TR3B Cylinder Head Triumph 7
af3683 TR2/3/3A TR3B Signal Flasher Problem? Triumph 2
B TR2/3/3A where to buy oversize thrust washers for TR3B? Triumph 16
B TR2/3/3A Identify the Mystery Bolts from TR3B front and interior Triumph 2
T TR2/3/3A TR3B fuel gauge Triumph 3
T TR2/3/3A TR3B stanchion to frame scew size Triumph 8
T TR2/3/3A TR3B alternator leak Triumph 4
T TR2/3/3A TR3B steering wheel cover Triumph 25
T TR2/3/3A TR3B VB windshield Triumph 11
M TR2/3/3A TR3B Front suspension Triumph 5
T TR2/3/3A TR3B gas cap Triumph 0
T TR2/3/3A TR3B steering column felt bushing Triumph 2
V TR2/3/3A TR3B Engine Oil Triumph 8
af3683 TR2/3/3A TR3B Rear Handbrake Cables Triumph 8
T TR2/3/3A TR3B horn wiring Triumph 4
