TR2/3/3A TR3B VB windshield
TFB
I recieved my new windshield and matching sealing strip from VB.Concerned about breakage and reading here about some strips being to thick I decided to fit the old winshield as practice and to check fit.The supplied strip seems to thick,about 2x the original .The new windshield measures .246 and the old is .264 so the strip may be ok.Havent tried it yet.
Has anyone installed on of the VB windshields and used the supplied strip?
Any lubricant recommendations?
Thanks
Tom
luke44
There are a few tricks for sure. This thread may be of value....I think my the seals and rubber came from TRF, but I referenced Moss part numbers because they have the diagrams online and were easier to link to. The glass I used was off an ebay vendor and was a tad thinner than original but I didn't measure it. My guess is it would be the same producer used by VB. Good luck!
https://www.britishcarforum.com/bcf...Step-by-Step&highlight=tr3+windshield+rebuild
T
TFB
Hey Luke,Thanks for reply.I actually found your excellent step by step after posting(BTW search feature on new forum seems much improved,thanks Basil)I like the duct tape idea. I still need the corner finishers,but they are later style than yours,and NA so will probabley make them as last step.Your car looks great,hope to see it at some shows ,maybe the shore this year?
Thanks
Tom
MDCanaday
Do a dry fit first!!!! VB has had a bad batch of wind screens for tr3's that were badly cut in the corners.They just dont work.
They may have gotten better ones,but last I checked(I live close) they were all alike.....In any case it is easier to use the strips in a few places then ureathane the whole thing together. Dont worry about the mess,it all cleans up in a snap when dry. Takes a fraction of the time and never leaks(here).
MD
bobhustead
As for the lube, I used crisco on mine. Use moderate amounts on the splines and the grooves so you can keep a good grip on the business part. Inchworm it in, pulling the bitter end tight, then pushing the standing part.
Bob
PKPoole
Hello. From the lessons learned (by breaking the 1st glass!), order the MGA windshield seal from Moss. It is thinner and much easier to make the assembly. Good luck.
TuffTR250
I just received a TR3 windshield from VB and as you say the lower corners are not good. It has one pretty bad corner and one that is not good. It looks like one piece of the laminated glass has nice round corners whereas the other piece has somewhat pointed sharp corners. They obviously did not round the corners after the two pieces of glass were laminated together. Is there any way to round the corners without breaking the glass?? Would some kind if grinding wheel on a Dremel do the job? Thanks for the help!
Regards,
Bob
Crankshaft
I'm not sure I would use a grinder or even a dremel tool. If there is a small amount to dress off, try some emery cloth and a sanding block.
l
TuffTR250
Thanks Phil! There's about 1/8 inch of pointed glass sticking out. Good idea to use sanding block and emery cloth. Hopefully I can sand down that much glass. I am leery of using a dremel, but couldn't think of anything else that might do the job.
Regards,
Bob
George_H
DO NOT use a dremel. Heat is the enemey when grinding glass. If you try and grind without coolant you will break it. laminated and tempered makes it even worse. It can be sanded by hand but will take some time.
MDCanaday
If you go to a glass shop this is easy......but VB owes you for this BS ,they have known for 2 years they have a bad product.
No idea where these windscreens came from but I have seen several that the glass did NOT reach the corners and left a hole you could poke a pencil through.
This of course would cause a water leak that might drown the hardiest sidescreen driver!!
MD
T
TFB
I still havent fit the VB glass to the frame but the corner profile seems to match the original.I did test fit the supplied seal strip and at about .060 seemed to thick,although a little nicer with a fabric type side and a smooth side.The MGA strip they sent is about .030 and although its more like a bicycle rim strip smooth rubber it fits better and is what I am intendending to use,unless I have problems,then I will probably use a urethane.It will be after New year but I will report on the fit when done.
Tom
tr3guy TR2/3/3A Late TR3A, TR3B windshield assemply Triumph 5
K TR2/3/3A Windshield stanchions on a TR3b - guide plates?? Triumph 13
T TR2/3/3A TR3b windshield parts Triumph 2
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
AngliaGT TR2/3/3A Value of a One Owner,Excellent Condition TR3B ? Triumph 12
glemon TR2/3/3A TR3B Triumph 10
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
P TR2/3/3A TR3B SU carbs Triumph 10
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
P TR3B Coil Issue? Triumph 7
P TR2/3/3A TR3B Panel Light Switch Triumph 20
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
af3683 TR2/3/3A TR3B Oil Drain Plug Triumph 10
J TR2/3/3A TR3b Tyres Triumph 6
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
W TR2/3/3A TR3B ‘TCF’ on BAT Triumph 10
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
M TR2/3/3A After Market Oil Filter - TR3B Triumph 8
M TR2/3/3A Technical Assistance Needed - TR3B Carb Adjustment Triumph 5
D TR2/3/3A Best TR3B seats - repair or replacement? Triumph 11
K TR2/3/3A Broken exhaust manifold TR3b Triumph 13
D TR2/3/3A TR3B Tire sizes? Triumph 10
S TR2/3/3A 155/15 Vredestein Sprint Classic on a 4.5" Wire Wheel as TR3B Spare? Triumph 6
J Restoring a '62 TR3B Restoration & Tools 2
M TR2/3/3A TR3B Door Cables Triumph 5
M Door Cables - 62 TR3B Spridgets 1
B TR2/3/3A Are these seat slides for a TR3B? how do you paint them? Triumph 8
B TR2/3/3A carpet snap questions tr3B Triumph 1
B TR2/3/3A TR3b lower door seal question Triumph 3
B TR2/3/3A tr3b center exhaust hanger Triumph 3
B TR2/3/3A steering box seal replacement TR3B Triumph 4
af3683 TR2/3/3A TR3B Exhaust Manifold Gaskets Triumph 15
C General TR TR3B Cylinder Head Triumph 7
af3683 TR2/3/3A TR3B Signal Flasher Problem? Triumph 2
B TR2/3/3A where to buy oversize thrust washers for TR3B? Triumph 16
B TR2/3/3A Identify the Mystery Bolts from TR3B front and interior Triumph 2
T TR2/3/3A TR3B fuel gauge Triumph 3
T TR2/3/3A TR3B stanchion to frame scew size Triumph 8
T TR2/3/3A TR3B alternator leak Triumph 4
T TR2/3/3A TR3B steering wheel cover Triumph 25
M TR2/3/3A TR3B Front suspension Triumph 5
T TR2/3/3A TR3B gas cap Triumph 0
T TR2/3/3A TR3B steering column felt bushing Triumph 2
V TR2/3/3A TR3B Engine Oil Triumph 8
af3683 TR2/3/3A TR3B Rear Handbrake Cables Triumph 8
