TR2/3/3A TR3B horn wiring
TFB
Old wires feeding horns appear to be two 12 g,one for each horn,on their own fuse and 12g gound wires inside horn from old harness.
The new stering column harness horn ground looks like a 16g that willl carry the ground for both horns.
I would like to avoid a relay,but may go that way.
Am I missing something? Why such small ground for both horns?
Where does horn ground get back to chassiss?through the column brace?
Also if i do use a relay,do I need one 10g for fused power and would it make more sense if relay is used to ground horns at base and send + from relay?
Also what is american fuse size for the horns,I believe A1.
Thanks
Tom
TR3driver
Great Pumpkin - R.I.P
The harness through the steering column has to be small enough to pass through the space. I didn't try to measure, but I suspect you'll find that the conductor is bigger than it looks (and the insulation thinner). In any case, that is how it was wired originally.
I'm not sure which path the current follows, whether through the brace or through the steering box, but I would guess the latter. There are felt and nylon bushings between the steering wheel/shaft and the outer column.
Not sure I follow your relay comments. 12 AWG should be plenty, but using 10 certainly won't hurt anything. And the relay can be wired on either side of the horns. Mine is on the ground side, to minimize wiring changes.
Later cars used a Lucas 35 amp for the horns, so AGC 20 would be a suitable substitute.
T
TFB
Thanks Randall,
The 10g power question was because I see originally each horn had it's own 12g,and I would be feeding both with one 12g if I run one power to the relay so I thought maybe a 10g.
Was it horn contact damage or stator tube harness wiring that lead you to install the relay?
BTW thanks also for your suggestion in a previous post about 5-8 amp od fusing to protect the od solenoid if it hangs up.Im running an all new harness so I put a 5 inline,and will increase if needed.
Thanks again
Tom
TR3driver
At the time, I thought it was contact damage; but I later discovered that the 4-way sleeve was broken internally and not making good contact with the bullets. This is where the wire originally from the control head meets with the wire to each horn.
Now I think I may just have a flaky horn, but I haven't gone back in to troubleshoot.
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
AngliaGT TR2/3/3A Value of a One Owner,Excellent Condition TR3B ? Triumph 12
glemon TR2/3/3A TR3B Triumph 10
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
P TR2/3/3A TR3B SU carbs Triumph 10
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
P TR3B Coil Issue? Triumph 7
P TR2/3/3A TR3B Panel Light Switch Triumph 20
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
af3683 TR2/3/3A TR3B Oil Drain Plug Triumph 10
J TR2/3/3A TR3b Tyres Triumph 6
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
W TR2/3/3A TR3B ‘TCF’ on BAT Triumph 10
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
tr3guy TR2/3/3A Late TR3A, TR3B windshield assemply Triumph 5
K TR2/3/3A Windshield stanchions on a TR3b - guide plates?? Triumph 13
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
M TR2/3/3A After Market Oil Filter - TR3B Triumph 8
M TR2/3/3A Technical Assistance Needed - TR3B Carb Adjustment Triumph 5
D TR2/3/3A Best TR3B seats - repair or replacement? Triumph 11
K TR2/3/3A Broken exhaust manifold TR3b Triumph 13
D TR2/3/3A TR3B Tire sizes? Triumph 10
S TR2/3/3A 155/15 Vredestein Sprint Classic on a 4.5" Wire Wheel as TR3B Spare? Triumph 6
J Restoring a '62 TR3B Restoration & Tools 2
M TR2/3/3A TR3B Door Cables Triumph 5
M Door Cables - 62 TR3B Spridgets 1
B TR2/3/3A Are these seat slides for a TR3B? how do you paint them? Triumph 8
B TR2/3/3A carpet snap questions tr3B Triumph 1
B TR2/3/3A TR3b lower door seal question Triumph 3
B TR2/3/3A tr3b center exhaust hanger Triumph 3
B TR2/3/3A steering box seal replacement TR3B Triumph 4
af3683 TR2/3/3A TR3B Exhaust Manifold Gaskets Triumph 15
C General TR TR3B Cylinder Head Triumph 7
af3683 TR2/3/3A TR3B Signal Flasher Problem? Triumph 2
B TR2/3/3A where to buy oversize thrust washers for TR3B? Triumph 16
B TR2/3/3A Identify the Mystery Bolts from TR3B front and interior Triumph 2
T TR2/3/3A TR3B fuel gauge Triumph 3
T TR2/3/3A TR3B stanchion to frame scew size Triumph 8
T TR2/3/3A TR3B alternator leak Triumph 4
T TR2/3/3A TR3B steering wheel cover Triumph 25
T TR2/3/3A TR3B VB windshield Triumph 11
M TR2/3/3A TR3B Front suspension Triumph 5
T TR2/3/3A TR3B gas cap Triumph 0
T TR2/3/3A TR3B steering column felt bushing Triumph 2
V TR2/3/3A TR3B Engine Oil Triumph 8
af3683 TR2/3/3A TR3B Rear Handbrake Cables Triumph 8
