TR2/3/3A Engine rebuild
sp53
Engine rebuild, well I took my engine block in to see if they could hone out the sleeves because of the rust. They basically did not want to deal with it because it was too iffy. The old timer there suggested a ball hone at home and see where that gets me. I had one and did that, and I think they will be ok because the rust seemed to be more of a varnish and the hone did not appear to take off much metal Perhaps, because of the type of metal the sleeves are made. Moreover, the sleeves slid out of the block. Anyways,I am thinking of having them do what they call “shake and bake” where they blast the motor with metal pellets and bake it then flush it out. I had that done once and worried about the pellets because I did find some in the first couple of oil changes, but the shop that did that work was having problems and soon went out of business.
If I go that route, they want all the plugs and cam bearings out, so I am looking for suggestions on cam bearing removal. Plus what I want to do is leave those two plugs in the back in place and work around them. Does that seem possible? The one is tin, but the other looks like aluminum or something.
tinman58
I have a set of 87mm piston and sleeves that only have about 8000 miles on them, if you want them pm me and they are yours.
croz
I highly recommend that you skip all that.
The motor is all ready disassembled so get the shop to steam clean it and get a new sleeve, piston and ring kit.
Steve
TFB
Ball hones are like sanding your body work with little pieces of sandpaper taped to you finger tips.Not good.A glaze beaker flexible hone is much better, like block sanding,a ridged hone better yet.
Tom
TR3driver
Great Pumpkin - R.I.P
I'm having a hard time with this picture. You want to do a full rebuild, but you're going to just hone the rust out of the cylinders and call them good enough? IMO you should pick one or the other. Either slap it together now (and expect to have it out again in a few years) or do it right. I've done a lot of the former, so I'm not knocking it, just don't fool yourself that you're "doing it right".
In other words, you may not be able to see those rust pits, but they are there. Machining (not just honing) to the next oversize is the only way to get rid of them.
CJD
Find a new machine shop. I have a great guy here in Fort Worth that I trust completely with my American iron. He won't touch my British parts. He acts like they are poison. You will have to find a shop that deals with the British parts. They are no harder to work with, but they are different. A shop has to be ready to set up for loose liners.
I am also not sure about baking a block. How hot are they heating it? Without care heating can cause warpage or cracks.
S
sp53
Well I guess they heat the motor to 500 degrees, I do know. Iam just cheap and I hate to throw away new liners and pistons just because theyare a little rusty, but maybe I should. Heck the manual talks about rotating the sleeves180 to get rid of piston slap, so there is some play somewhere. Every tr3 I havehad leaks oil and smokes a little anyway. I found a different machinist and he saidbring me out your stuff and I will measure it, and Tinman suggested he had somestuff that is not too bad, so I will see.
S
sp53
Thanks tinman I do not know what to say, those pistons and linerslook great. I am going to have to work hard to be as good of club member. I sayclub because this forum can be just like a club.
Thanks Steve
tdskip
Steve - I'd suggest you file this one under "things to do right" if you plan to keep the car. The cost of new pistons and sleeves will be fairly modest compared to an over all rebuild.
PatGalvin
SP53
I highly recommend that you change out the aluminum plug in back of block, if you hot tank or bake out your block.
I neglected to do so, and the leak resembled a rear seal leak. Cost me lots of time and money to remedy.
Super easy to replace and helps clean out oil gallery of sludge and debris if removed prior to block cleaning.
pat
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
KVH General Tech More Engine Rebuild Questions Triumph 15
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
J Engine rebuild Austin Healey 4
classicmechanic Amazon engine rebuild pics Other Cars 6
M 948 Engine Rebuild Question Spridgets 0
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
60TR3A Cost to Rebuild a Healey 3000 Engine [And Recommendations About Who to Do It] Austin Healey 14
M E Type 4.2 engine rebuild Jaguar 4
Got_All_4 TR6 TR6 engine rebuild. Too tight? Triumph 23
Healey Nut Engine rebuild Austin Healey 17
Got_All_4 TR6 What engine bearings to use in my rebuild? Triumph 9
R BT7 engine gallery plug replacement during rebuild Austin Healey 3
RAC68 What's with all the Engine Rebuild Failures? Austin Healey 42
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
G Failure on Initial Engine Start After Rebuild Austin Healey 176
HighAltitudeTR3 TR2/3/3A Any feedback on this? Rimmer Bros engine rebuild Triumph 6
KVH General Tech Engine Rebuild: Failed at Cam Break-in Triumph 11
simon1966 A few shots from the 100 engine rebuild Austin Healey 18
JimLaney Engine rebuild - how critical is rust? Spridgets 3
G TR4/4A A couple of engine rebuild questions... Triumph 8
N Engine rebuild ??? Spridgets 4
Csarneson BN4 Engine Rebuild Questions Austin Healey 8
Csarneson Engine Rebuild Disaster - Cylinder Crack Austin Healey 20
D Engine rebuild questions. Austin Healey 18
M Need Advice On 948 Engine Rebuild Spridgets 7
W TR2/3/3A Novice TR3 Engine Rebuild Triumph 47
W TR2/3/3A Engine rebuild - looking for preliminary advice Triumph 7
T TR4/4A What is trickiest part of engine rebuild? Triumph 15
D MGB 1963 MGB engine rebuild MG 4
H Off Topic Nifty Time-Lapse Video of Spitfire Engine Rebuild Triumph 2
gbtr6 TR6 Engine Rebuild kit Triumph 12
gbtr6 TR6 TR 6 Engine rebuild/freshen Triumph 21
Rut TR4/4A Performance engine rebuild Triumph 3
me61ic Timelapse '63 BJ7 engine rebuild Austin Healey 5
Rut MGB Engine rebuild, then... MG 29
mcmillal TR4/4A Engine / Transmission Rebuild Triumph 1
JPSmit Engine Rebuild question Restoration & Tools 10
TexasSprite Engine Rebuild Video Spridgets 1
Healey Nut Engine rebuild Austin Healey 9
mt10flyer TR2/3/3A 1959 TR3 engine rebuild problems Triumph 14
PatGalvin The fun just won't stop [engine rebuild questions] Triumph 53
Tim Tucker TR4/4A TR4 Engine rebuild Triumph 4
J TR4/4A Engine rebuild on a TR4 Triumph 19
MGTF1250Dave XPAG Engine Rebuild MG 0
B Engine Rebuild MG 1
Johnny Spitfire How to rebuild a Spitfire 4 cyl engine in 45 sec. Triumph 2
Sarastro Here's the REAL way to rebuild a Triumph engine! Triumph 1
luke44 Spitfire Spitfire Engine Rebuild- Great Video Triumph 2
HealeyRick 1500 Engine Rebuild Made Easy Spridgets 5
