Door Wood
CJD
Does anyone know the type wood used in the post 60k cars? It looks like walnut...my father thinks it's teak...
Thanks,
John
trrdster2000
CJD, Ashe and it's still used in Morgan's. Try to make a good template out of cardboard before you start, both sides and in some cases all four sides will be different.
Wayne
TR3driver
Great Pumpkin - R.I.P
+1 on ash.
CJD
CJD
Excellent. It had me fooled as it was very dark after the years. Ash is available at lowes...I was sweating having to find such a small amount of teak!?!
Thanks guys!
John
tr8todd
I fixed a Morgan door frame once that had enlarged screw holes. I made dowel pins by drilling out plugs from a baseball bat and then glueing them into the drilled out holes in the door frame.
PAUL161
I have to do that on my TF door frames. Most of the holes need plugging to reset the screws. Even though the wood is in excellent condition, 55 years of adjusting the latches has taken it's toll on the screws & holes. PJ
TR3driver
Same trick works with ordinary hardwood dowels from the hardware store.
CJD
CJD
My holes are all good. One board is cracked with a piece missing...so that one will have to be replaced. The piece is not anywhere in the door, showing the PO was aware - of course!
John
toysrrus
Howdy John,
You may want to check out "Macys Garage" as he supplies some nice door wood panels from what I can see. I have`nt bought any from Mark Macy but If Its the same Quality as all his stuff; You`ll be a Happy Camper.
Have Fun,
Russ
lbcs_r_fun
Thanks,
John
Your post made me chuckle. To think that Triumph would use something as exotic as teak! They went out of their way to save a penny or two - probably used old pallet wood. :devilgrin:
Seriously, our 3A doors have a very close grained wood - looks like mahogany, which was/is fairly cheap. Ash was popular where structural strength was an issue such as Morgans and early MG's, etc.
If you have decent patterns you can make your own for a fraction of the price that suppliers charge. Personally, I would glue-up some Baltic birch. You don't have to worry about grain direction with the plywood, and it is very strong. Use a good grade poly glue, e.g. gorilla, etc.
CJD
CJD
I'll take a look at Macy's...thanks for the tip.
You know, I really think mahogany might be what's in mine. I chipped at it a bit, and it is to solid to be rotted ash...but it is very dark all the way through.
Thanks,
John
S TR2/3/3A wood next to the door on a tr3 Triumph 4
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
TomMull TR2/3/3A door wood Triumph 36
toysrrus TR2/3/3A TR3 Door Wood; Who sells them? Triumph 1
A TR4/4A TR4 A wood glove box door question Triumph 0
YankeeTR TR2/3/3A TR2/Early 3 Door Wood Triumph 5
YankeeTR TR2/3/3A Where can you buy TR2 door wood? Triumph 11
Lin Wood block - door seal cap Austin Healey 0
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 5
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
chicken BJ7 Door Fit Austin Healey 27
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
F Door Panel Hardware Austin Healey 3
LAW75 Door Latch Adjustment Austin Healey 22
BoyRacer Door Panel Measurements Austin Healey 3
LAW75 BJ8 Door Locks Austin Healey 2
Cappy Occasional Door Malfunction Austin Healey 1
nichola TR6 Door handle and window crank installation Triumph 0
J Door Draught Metal Clips Austin Healey 4
F Interior Door Handle Removal Austin Healey 2
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
M Spitfire 1500 LH Door Triumph Classifieds 0
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
