TR2/3/3A Where can you buy TR2 door wood?
YankeeTR
Does anybody have a source for early TR door wood?
I haven't seen any in the "big three" catalogs. I do have a local outfit that makes "woodie" wood...in fact they build complete new woodie" bodies. I may drive up there later today to show him what I've got and see if he will replicate it.
But I'd like to get a cost comparison...or I could probably do it myself...I have access to a pretty nice woodworking shop.
Has anyone replaced the original ash wood with a treated wood like "yellow pine"? I would think that treated pine would be hard enough to do the job yet eliminate the rot problems...
tdskip
This is not the voice of experience speaking here - but wouldn't you 'just' make a new piece in the shop from the pattern old one? That is what I did with the MGA (albeit the floor).
YankeeTR
YankeeTR
[ QUOTE ]
[/ QUOTE ]
Skip,
You are right...but I'm a much better (MY opinion) metalworker than woodworker...I can always weld up my mistakes!
Seriously, the three parts are pretty simple but there is a concave shape to the top of the door wood that allows the aluminum door cap to seat into the wood...probably pretty simple to make by an experienced woodworker...but, like I said, .....
YankeeTR
YankeeTR
[ QUOTE ]
The concave shape would give me fits - maybe find an experienced shop that could make that specific part for you?
[/ QUOTE ]
I'm sure ther's a router bit designed to do that job...the piece that needs this is the top piece that follows the countour of the door...ez for a pro...probably not as ez for me...
I actually thought about casting this piece in resin...if I could get the original repaired enough to make a mold...
My brother restores old Jags...and he just recently built all new wood for a '36 SS-100 that he's restoring...maybe I could have him build it...but he's probably too expensive! /ubbthreads/images/graemlins/shocked.gif
YankeeTR
YankeeTR
[ QUOTE ]
Will early tr3 door wood fit?
Sp53
[/ QUOTE ]
Yep...that should be the same...my doors only have wood at the top to secure the door capping and the door latch assembly.
Mickey Richaud
YankeeTR
YankeeTR
[ QUOTE ]
You might want to take a look at Moss - they have steel top rails. Maybe replacements for the wooden parts? And they fit TR2's and 3's. Might give them a call to find out. Here's the page - check the entries after item # 11 - part nos. 803-585 and 803-595.
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=29160
[/ QUOTE ]
They show the parts but they are N/A...not available. I'm going to call TRF...
Mickey Richaud
[ QUOTE ]
As I look at the Moss site quoted above, it is the WOOD that is not available. Part 803-585 and 803-595 seem to be the separate pieces atop the door that hold the rubber (that gets wrapped with upholstery).
[/ QUOTE ]
That would be my guess as well, but they're named the same as the wooden parts (top rails). Confusing... /ubbthreads/images/graemlins/confused.gif
At any rate, the rails should be the same for 2's and 3's.
Mickey
YankeeTR
YankeeTR
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
TRF doesn't have them...and I couldn't find anything in Rimmer Bros. catalog, either.
The local woodworking guy isn't open this week...I'll do some other stuff to keep me busy and try him next week.
B MGA Where to Buy, What to Buy? Axle Nut MG 9
B Windshield glass, where to buy Restoration & Tools 4
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
AngliaGT Midget Parts - Where to buy? Spridgets 11
M TR4/4A Where to buy replacement TR4 exterior door handles? Triumph 1
F Spitfire Where to buy Stripe Kit Triumph 1
T TR2/3/3A Where to buy steel TR3A battery box? Triumph 8
MY66AH Where to buy a new crank Spridgets 40
B WHEELS- Where to Buy Triumph 4
B TR2/3/3A where to buy oversize thrust washers for TR3B? Triumph 16
Zitch Leaky SUs where to buy rebuild Triumph 22
D Where in N. Va. to buy/ mounts tires on wire wheel Austin Healey 3
Mychael Where to buy quality pedal rubbers. Spridgets 2
M Where would you buy your next fuel tank? Austin Healey 6
C TR2/3/3A Where to buy front calipers for an early[57] TR3? Triumph 7
60Bugeye Where to buy Bugeye Body Panels? Spridgets 13
T Where buy bullet connectors locally [ie pick up]? Triumph 15
W 90 GL$ Where to buy???? Triumph 12
richberman Where to buy Q-H bushings? Austin Healey 1
PatGalvin TR2/3/3A TR3 Fuel Line - where to buy? Triumph 7
T Where to buy bolts that secure door latch Triumph 10
B where to buy 175/80r15's? Austin Healey 11
P Where to buy a Parts Washer! Restoration & Tools 10
H WHERE TO BUY A CLUTCH M/C PUSHROD? Triumph 5
hondo402000 TR6 ARP Head stud kit 71 TR6[ Where to buy] Triumph 10
D T-Series Where to buy clutch parts MG 5
soren_ak where do u buy your healey parts guys ? Austin Healey 8
Gerdo Fuel Float? Where to buy? Triumph 8
Geo Hahn Redlines - Where to buy Triumph 3
L Where to Buy Replacement Rocker Panels-Frustrated! Austin Healey 5
B TR6 Where can I buy a trunk kit for a TR6? Triumph 6
M Where can I buy my spouse TR6 things - T-shirts? Other British Cars 4
B Need Advice: Where to buy...? Spridgets 1
356roadster brake drums for early 100 bn1: where to buy? Austin Healey 16
J Where to buy aluminum door trim. Austin Healey 3
J Where to buy windshield and rubber parts. Austin Healey 5
T Where to buy Factory Grade Paint? Triumph 6
Z TR6 Where to buy TR6 Soft Top Triumph 7
tr6web Paint - where to buy it? Triumph 3
RobSelina where to buy springs Spridgets 7
K MGB where can i buy mirror for a MGB Roadster 1971 ?? MG 3
V Where to buy headers Triumph 0
Steve Where do you buy tools? Restoration & Tools 14
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
