Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
CJD, Ashe and it's still used in Morgan's. Try to make a good template out of cardboard before you start, both sides and in some cases all four sides will be different.
Not much wood, though, on the TS60001 and later cars, though, other than blocks into which the screws for the sidescreen curtains go, and an odd tack strip or two behind the doors? At any rate, no "framing" wood that I recall.
Excellent. It had me fooled as it was very dark after the years. Ash is available at lowes...I was sweating having to find such a small amount of teak!?!
I fixed a Morgan door frame once that had enlarged screw holes. I made dowel pins by drilling out plugs from a baseball bat and then glueing them into the drilled out holes in the door frame.
I have to do that on my TF door frames. Most of the holes need plugging to reset the screws. Even though the wood is in excellent condition, 55 years of adjusting the latches has taken it's toll on the screws & holes. PJ
My holes are all good. One board is cracked with a piece missing...so that one will have to be replaced. The piece is not anywhere in the door, showing the PO was aware - of course!
You may want to check out "Macys Garage" as he supplies some nice door wood panels from what I can see. I have`nt bought any from Mark Macy but If Its the same Quality as all his stuff; You`ll be a Happy Camper.
Your post made me chuckle. To think that Triumph would use something as exotic as teak! They went out of their way to save a penny or two - probably used old pallet wood.
Seriously, our 3A doors have a very close grained wood - looks like mahogany, which was/is fairly cheap. Ash was popular where structural strength was an issue such as Morgans and early MG's, etc.
If you have decent patterns you can make your own for a fraction of the price that suppliers charge. Personally, I would glue-up some Baltic birch. You don't have to worry about grain direction with the plywood, and it is very strong. Use a good grade poly glue, e.g. gorilla, etc.
You know, I really think mahogany might be what's in mine. I chipped at it a bit, and it is to solid to be rotted ash...but it is very dark all the way through.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
