Clutch Question
MG_Midget_74
I am new here, however I have owned my '74 Midget for about 30 years. I discovered that by closing the vent hole on the clutch master cylinder hole, the one in the cap, my clutch travel improved. I know why would this be, got me, but it was real, any thoughts?
Helping a leaking seal build and retain pressure?
Oh, BTW ... Welcome to the Forum.
M
MG_Midget_74
The master, is not leaking and was rebuilt by Apple Hydr, about a year ago, the slave is probably leaking and will be dealt with when the season ends. The master leaking and sealing the hole makes sense, the slave does not.
PeterC
You are essentially holding your thumb over the end of the straw. I suspect that the slave cylinder is not fully retracting giving the feel of better pedal travel. I wouldn't keep doing that were I you.
However, a useful "trick" when you get around to replacing the slave or working on any other hydraulic component is to fill the master and cover the reservoir with a plastic bag then put the cap on. This way, when you undo a hose or line, very little fluid will drip out, and bleeding time will be minimal to almost non-existent. (especially if you install the slave with the piston pushed all the way in)
And..... welcome aboard!
Peter C.
B TR6 TR6 1976 Clutch Choice Question Triumph 3
D TR2/3/3A clutch/brake pedal question Triumph 4
KVH General TR Overdrive Up-date and Clutch Question Triumph 2
AndreL TR6 Clutch question Triumph 2
W General Tech Clutch Release Question Triumph 6
S XJ6 Mk1 clutch slave question Jaguar 0
toysrrus TR6 Clutch fluid question Triumph 4
M_Pied_Lourd TR2/3/3A TR6 Transmission Swap Clutch Slave Question Triumph 3
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
Marvin Gruber Big Healey clutch question Austin Healey 3
T Clutch release bearing question Spridgets 10
A TR2/3/3A Clutch Question Triumph 4
2billydavies TR2/3/3A Question about size of Clutch Alignment Tool Triumph 9
M_Pied_Lourd TR2/3/3A Brake and Clutch Master Pushrod Question Triumph 4
Zimmycobra TR4/4A Clutch hydraullics question Triumph 25
JPSmit Trivia question - clutch hydraulics Spridgets 16
toysrrus TR6 TR6 & GT6 Flywheel, Clutch question: Triumph 4
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
Zimmycobra TR4/4A TR4A Clutch adjustment question Triumph 2
TR4A_IRS TR4/4A Question about TR4A Clutch line fitting specifications Triumph 1
bugedd Rivergate clutch question Spridgets 0
RAC68 A Quick Question [Clutch Master Seals] Austin Healey 2
T TR2/3/3A tr3 brake/clutch reservior question Triumph 1
W BN2 clutch cover or pressure plate question Austin Healey 2
C TR2/3/3A New member and newbie question on TR3 clutch Triumph 26
JPSmit 1500 Clutch hose question Spridgets 8
P Clutch replacement question British Motor Corp 1
hondo402000 TR6 TR6 Clutch question Triumph 5
H Clutch question Triumph 10
R clutch push rod replacement question Spridgets 6
dklawson Rhetorical Question/Comment - Use of Clutch Pedal? Triumph 29
Ohiobugeye Another Clutch Hydraulic Line Question Spridgets 2
Stinger TR4/4A TR4A Clutch Question Triumph 7
Tabcon Restoration Up-date & Clutch Question Triumph 23
SherpaPilot TR6 TR6 Clutch Question Triumph 3
davidk Clutch Pressure Plate Question Triumph 9
E Rivergate Clutch question Spridgets 2
theleisure quick clutch question Spridgets 10
H T-Series Tranny/Clutch question MG 3
M Clutch Question Spridgets 9
JPSmit Qucik Question #1 Clutch slave cylinder Spridgets 2
GT6_Mark T-Series MGC Clutch Fork Question MG 1
J clutch question Spridgets 2
R spitfire OD in MG midget, trany & clutch question Spridgets 4
CCURTISS TR4/4A TR3/TR4 Clutch Fork Install Question Triumph 8
T Clutch hose question Triumph 21
C brake & clutch master cylinder question Austin Healey 2
M Clutch Question Spridgets 3
J T-Series TD clutch actuation part question MG 1
M Shifting Issue: Clutch Question Spridgets 4
