Clutch replacement question
PeterC
1964 car. Never done a clutch in a Mini.
Are the instructions per the Haynes manual accurate for replacing with engine in the car? Any other tips? I will likely be examining and replacing some oil seals, too.
Thanks for any input.
Peter C
R clutch push rod replacement question Spridgets 6
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
S MGB clutch replacement MG 7
Marvin Gruber Clutch replacement on BJ8 Austin Healey 5
R TR6 Clutch Replacement Triumph 6
PatGalvin TR5/TR250 Clutch Replacement Recommendations Triumph 4
RedTR3 Clutch Replacement Triumph 9
BoneIdle T-Series Clutch replacement MG 17
philman saab 900 clutch replacement Other Cars 6
J Clutch replacement Spridgets 17
A trf clutch replacement Triumph 31
roofman TR6 Tr6 clutch slave cylinder replacement Triumph 11
J Spitfire Clutch Slave and master replacement , 78 Spitfire Triumph 13
A Clutch Replacement + Rear Crank Oil Seal Replace? Austin Healey 8
Scott_Hower T-Series Clutch hose replacement MG 32
TR_Jim Clutch shaft replacement Triumph 2
johnrip Wedge tr7 5 speed clutch replacement Triumph 1
P mastercylinder, brake & clutch replacement Austin Healey 20
K TR4/4A Clutch Replacement on TR4A. need advice Triumph 11
G Clutch Master Cylinder Replacement Austin Healey 6
MGTF1250Dave TR2/3/3A TR3 CLUTCH FRICTION DISC REPLACEMENT Triumph 9
C TR6 Request for more advice on a TR-6 clutch replacement Triumph 4
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
