I have to stay with Randall. If you have a good working clutch, continue to use it. Some of the new "kits" just don't last or work. Do inspect the existing clutch for wear. Look at the arms were the TOB runs. If worn replace. Clutch plate, if the rivets are close to the surface, change it. TOB rattles or dry sounding replace it.
Marv
