TR6 Clutch fluid question
toysrrus
Hi Folks,
What is the best recommended "CLUTCH FLUID" for a TR6? Mine is a '71. I have "Dot 5" in the Brake Master Cyl.
Thanx for your opinions.
Russ
TR3driver
Great Pumpkin - R.I.P
Essentially the same debate for clutch fluid as for brake fluid. Some love DOT 5, some hate it. I'm part of the first group.
Rut
Russ,
I would use the same in both regardless of the type.
Rut
Geo Hahn
It would never occur to me to use a different fluid in the clutch system v the brakes - possibly because of years with a TR3 (same reservoir can). I use DOT5 - if anything I would think the problems some seem to experience with it would be even easier to overcome in the clutch system (smaller capacity, only one bleed, can possibly do a gravity bleed).
toysrrus
toysrrus
Thanx folks for the quick replies.
"Dot 5" it is.
Regards, Russ
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
D T-Series Question on clutch fluid and pedal MG 4
Lin Brake/Clutch Fluid Austin Healey 11
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
longbridgehealey Clutch fluid Spridgets 7
warwick-steve Clutch master cylinder to fluid reservoir leak Austin Healey 5
S Clutch Fluid / Brake Fluid consumption Spridgets 3
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
RJS TR4/4A Clutch Fluid Very Dark After One Year Triumph 5
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
Jim_Newman brake/clutch fluid reservoir Austin Healey 4
B Clutch pedal no fluid? 2 -3 years of sitting... Spridgets 30
richberman brakes/clutch fluid out top of brake reservoir Austin Healey 11
RAC68 BJ8 Brake/Clutch Reservoir Fluid Loss Austin Healey 14
G T-Series Clutch fluid MG 2
D Mysterious clutch fluid loss Triumph 9
knad2208 Hydraulic Clutch Fluid Spridgets 1
Bruce_B Fluid for MC Brake and Clutch?? Synthetic--REgular Spridgets 4
B What Kind of Clutch Fluid? Spridgets 4
zimmy clutch fluid types Spridgets 4
I TR6 Correct clutch master cylinder fluid for 69TR6? Triumph 5
F Brake and clutch fluid 73 TR6 Spridgets 9
VelodromeRacer Clutch fluid to run... Racing 5
Rob_P T-Series Ugh, clutch fluid all gone... MG 12
X T-Series Sooty exhaust pipe & loosing clutch fluid MG 0
BritCarFan Silicone brake and clutch fluid British Motor Corp 7
H BRAKE/CLUTCH FLUID Triumph 28
P Clutch fluid query Spridgets 1
H Which Part of the Brake Fluid Canister for Clutch? Austin Healey 8
C T-Series Brake/clutch fluid MG 9
S Clutch Fluid Mystery Jaguar 2
T reminder-brake & clutch fluid Triumph 16
tr6web Brake versus clutch fluid Triumph 14
P Ran out of Fluid...Clutch Pedal Pressure... Austin Healey 10
S T-Series Where did my clutch fluid go... MG 7
S T-Series brake & clutch fluid MG 2
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
