Fluid for MC Brake and Clutch?? Synthetic--REgular
Bruce_B
I've got a new clutch and brake MC. The clutch line and slave are also new - might use synthetic fluid in that.
I'll be using Castrol DOT4 for the brakes, since those lines are all existing ones. Is there a way to 'rinse' them out so I can use synthetic all around?
Bruce_B
Bruce_B
Just came across this information while researching my own question.
Came from gerardsgarage.com (great web site):
This tip comes from Joe Way of Sierra Specialty Automotive
Most modern brake rubber is made of EPDM, and there is definitely no problem with it and silicone. The currently available Spridget rebuild kits, packaged in the clear plastic bags with the white labels, are made by a British company called Nelson-Stokes using a proprietary rubber compound. So far as I know, there is no problem with their rubber and silicone.
The issue is that silicone fluid is not nearly as good a lubricant as glycol fluid. In a brake system this is not really a problem since once the system is bled the pistons move only a fraction of an inch at each application, and the applications are relatively infrequent. But a clutch system is of a type sometimes referred to as "long-travel" because the pistons travel through their full stroke at every application, and the clutch is typically used much more frequently than the brakes. So there is a LOT of piston movement in the clutch, and the poor lubricity of silicone will cause accelerated wear of seals, bore and pistons.
Silicone is specifically NOT recommended for clutch systems, and there is of course no way to separate the two systems in a Spridget dual cylinder.
Gearhead
do your self a favor and just stick with Castrol brake fluid I believe its called Castrol LMF you can't go wrong with it
Bruce_B
Bruce_B
Gearhead...that's what I always use...every now and then I fall for
the advertising!!...Castrol it will be.
thanks all.
Lin Brake/Clutch Fluid Austin Healey 11
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
S Clutch Fluid / Brake Fluid consumption Spridgets 3
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
Jim_Newman brake/clutch fluid reservoir Austin Healey 4
richberman brakes/clutch fluid out top of brake reservoir Austin Healey 11
RAC68 BJ8 Brake/Clutch Reservoir Fluid Loss Austin Healey 14
F Brake and clutch fluid 73 TR6 Spridgets 9
BritCarFan Silicone brake and clutch fluid British Motor Corp 7
H BRAKE/CLUTCH FLUID Triumph 28
H Which Part of the Brake Fluid Canister for Clutch? Austin Healey 8
C T-Series Brake/clutch fluid MG 9
T reminder-brake & clutch fluid Triumph 16
tr6web Brake versus clutch fluid Triumph 14
S T-Series brake & clutch fluid MG 2
6 Brake Fluid Spridgets 4
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
P TR6 Brake fluid leak? Triumph 6
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
D TR2/3/3A Why it is important to change brake fluid Triumph 4
D TR2/3/3A Brake fluid identification by colour. Triumph 4
R TR2/3/3A DOT 5 Brake Fluid Triumph 5
Martinld123 Brake Fluid Austin Healey 49
Bayless Brake fluid recommendations Restoration & Tools 6
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
KVH General TR Dot 4 Brake Fluid Triumph 7
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
tahoe healey Brake Fluid Austin Healey 6
2 TR2/3/3A DOT5 brake fluid Triumph 3
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
M Brake fluid on tire - cylinder need replaced? Spridgets 19
B General MG Brake fluid MG 7
R TR2/3/3A Brake Fluid Triumph 6
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
G Brake fluid missing Austin Healey 6
Joe Schlosser Brake Fluid Spridgets 5
steveg Silicone brake fluid conversion - existing system Austin Healey 41
simon1966 Brake fluid Canister on a RHD 100 Austin Healey 10
Rut Brake fluid Spridgets 11
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
L 100/6 BN4 Brake fluid Austin Healey 17
M Losing Brake Fluid Austin Healey 8
