Tabcon
Restoration Update & Clutch Question
It now seems as though the end of this month will mark a significant point in my restomod for the TR4. Tony @ Ratco said my frame will be delivered to me by this date, my cylinder head, now being tweaked by Jerry Barker will be ready and my engine block, which needed a little deck aligining, will also be ready. Most all of the components will be in place and ready to mount to the frame, except suspension and wheels. Nothing on the body yet, but at last I have found a competent local painter.
My gearbox has been gone through and cleaned. It was rebuilt by Quantum Mechanics about 3,500 miles ago, but do to sitting up, it needed new seals and a few other adjustments.
[img:center]https://www.britishcarforum.com/bcforum/photopost/showphoto.php?photo=3506[/img]
As you can se, I'm all ready to use the standard type release bearing set up, but I was thinking of using the Tilton hydraulic bolt on release instead. My question is: Have any of you actually used this conversion and is it worthwhile?
