TR6 Carb float chambers
ceedub
Finally got my '72 TR6 on the road after three and a half years of a frame off resto. One thing that I am noticing is the number of cranks required to start the motor after the car has been sitting for a couple of days. Once started, any subsequent starts during the day happen right away. The opinions that I have is that the float chambers are somehow becoming depleted of fuel after sitting for a few days requiring so many cranks for the pump to refill the bowls. Is there a possibility that the fuel is somehow siphoning back? There does not appear to be any fuel leaks around the bowl or pump. Would a one way valve in the fuel line be of any use? There does seem to be a slight gassy smell in the garage but I can't figure out where it is coming from. Any opinions as to a solution to keep these bowls full over time? Thanks.
Ceedub
Gliderman8
Check the plug and O-ring on the bottom of the float bowl. The O-rings dry out and they can leak.
M_Pied_Lourd
And check the fittings that enter and exit the fuel pump....
Cheers
Tush
dklawson
For the o-rings, don't feel obligated to buy a rebuild kit to get what you need. Measure the gland diameter and the cross-section of the old o-ring. I forget the exact size but these are seals you can source at a local bearing house or auto parts store. (They are inch size... and in inch o-rings, sizes are nominal... i.e. a 1/16" cross-section o-ring is really 0.070" thick... so loosely interpret the size you measure). Buy Viton if they have it. The original seal would have been Buna-N (Nitrile). Both materials are fine with gasoline but Viton holds up a little better/longer.
poolboy
Maybe it's the choke that needs adjusting or the ignition timing is off.
BUT..there is a way to determine if there is fuel in the float chamber after the engine has been sitting idle for a few days..
If you want to try that, remove the air cleaner housing.
On the carb's air box mounting flange you'll see a round hole at about 10 o'clock, in between the 2 threaded holes...it's a vent.
Get a soda straw or tube and while lifting the air valve use the tube to blow into the vent.
If there is gas in the float chamber, it'll bubble up around the needle.
C
ceedub
Thanks for the tips folks. I did put a carb kit in with the restoration so the O-ring is new. Can't see or feel any leaks around the pump. I will give the soda straw a go to see if there really is any fuel in the bowl and get back to you. Is there any chance that fuel could be siphoning out of the bowl? I understand that the pump has a one way valve built in but who knows. Maybe another one way valve somewhere in the line would help if the bowl is empty?
Ceedub
poolboy
No, I don't see the possibility of fuel syphoning out of the float chamber. The fuel level isn't high enough to reach the float chamber needle valve in the fuel inlet port.
trrdster2000
Check the valve in the fuel pump. They go bad once in a while and will not hold fuel or pressure if they set for any length of time. You can get rebuild kits, or a new one. Unscrew the out line after it sets a day or two and see if fuel is in the line.
Wayne
H Forgot Positioning of Lids on Carb Float Chambers Austin Healey 4
S Carb Float Levers Austin Healey 9
T TR6 Carb. Float Chamber Fix Triumph 5
Healey Nut Carb float Austin Healey 16
steveg Carb float setting tool Austin Healey 11
H TR2/3/3A SU Carb Float Question Triumph 18
P BJ8 SU carb float level Austin Healey 6
BillyB62 TR2/3/3A Front Float Cover Lid for TR3 H6 Carb Triumph 10
Jeepster HD8 carb float bowls Austin Healey 7
glemon SU Carb question float level/leaner/richer Austin Healey 2
BugeyeNJ58 Carb leaking HS2 at bottom of float chamber Spridgets 21
Jim_Gruber SU Carb Float Valves Spridgets 9
J HD8 carb float adjustment. Austin Healey 1
A carb float bowl gasket Triumph 7
E TR2/3/3A TR3 carb float bowl Triumph 5
chicken is this the correct float for a HS6 carb on a BJ7 Austin Healey 4
N TR6 TR6 Carb Float Adjustments Triumph 3
NutmegCT H6 carb - float vents Triumph 4
MGTF1250Dave SU H6 Carb, Float Bowl Mounting Bolt Triumph 2
A TR4/4A TR4 HS6 carb float bowl lid orientation Triumph 2
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
