TR4/4A TR4 HS6 carb float bowl lid orientation
Adrio
Does anyone happen to know if the orientaion of the float bowl lid on the bowl of the HS6 carb is significant. I notice that the lid can go on in any of three positions. But given that the engine is slightly nose up and the front and rear carbs are mirror images, I was wondering if there is a "correct" way of putting the float lids on.
While trying to figure out my backfire problem, I noticed that the front carb has the fuel level higher then the rear carb. No amount of float level adjusting seems to change this. In fact adjusting the float level seems to hardly change the fuel level. I have checked and verified the float, the flat needle and seat and they are working fine.
I am grasping at straws but thought this might be significant and I hope someone knows if this orientation is significant.
gbtr6
You could try different positions. I adjusted mine for ease of mounting the fuel lines. Also, try the Grose jets. They help. Perry
piman
Hello Adrio,
the orientation is irrelevant, just set them to suit the fuel lines. There are, I believe, three different floats that were used in HS units, Brass - 5\16" setting, plastic and metal arm - 1\8" to 3\16" and the later all plastic 1\16" to 3\16" so there is some variation. The latter are not adjustable in the normal fashion as there is no arm to bend, but what thickness washer that is fitted to the needle jet body can affect the fuel level.
How severe is the backfire, I take it you are talking about a backfire on the over run? It could be an air leak on the exhaust manifold\front pipe or some over fuelling perhaps from the carburettor(s) not closing with the throttle off (unlikely if it idles easily)If your units have the little poppet disc in the throttle plates, try sealing them off?
Alec
S TR4/4A HS6 carbs in tr4 Triumph 4
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
Twit TR4/4A early tr4 check straps Triumph 4
