BN7 door latch adjustment
TimK
For 27 years, my driver's door has been loose by 1/8" to 1/4". It is not apparent to me how to adjust the latch -- on the door? or on the pillar? Before I go start randomly taking things apart, could someone please give me a clue?
On my 100-6 my passenger door would shut loosely and my driver's door too tightly. I found two metal plates or shims on the driver's side behind the shut face panel and the latch, so I removed one of them, and the door worked perfectly. Feeling pretty good about that success, I removed the shut face panel on the passenger side, and discovered no shims. So of course I put the one I had taken off the driver's side and put it on the passenger side, and the door shut quite nicely. Don't know if this is your problem, but it's worth a try. See if there are any metal plates behind the shut face panel.
Good luck,
Larry :smile:
TimK
TimK
Thanks for your comments, Larry, what I am looking for is information on whether the chrome latch (the piece with a hole in it that the door latch catches)can be moved inboard to make the door pull up tighter. Or is there an adjustment mechanism in the door that allows the latch to slide outboard to again pull the door tighter? Your example sounds like the shut face piece is moving with shims back or forward (in relation to the front of the car or back of the car) rather than inboard or outboard (side to side). Am I understanding you correctly? My problem is inboard outboard.
Keoke
Well Tim, I really do mot know that much about your model car. However, generally when the door has inboard outboard play it can be traced to:
1] Incorrect or worn draught excluder
2] Excessively worn parts in the latch assembly
3] improper adjustment of the Striker mounted on ---------the "Pillar"
The striker #3 is adjustable such that it can be slid inboard or outboard as required.--Fwiw-- Keoke
TimK
TimK
Thanks, Keoke. So I will take off the striker (four screws) and see what it looks like underneath.
Yep, on mine it was backward or forward to cure the door setting tight when shut. Sounds like Keoke is on the right track for your issue - Good luck!
Larry
TimK
TimK
I took off the striker plate and found that I was at the limit of adjustment. There is a plate behind the door pillar that the striker screws into. There are 4 diagonal slots that provide some adjustment inboard and outboard. Mine seems to be at the limit of inboard adjustment, so I may have to grind some more slots all the way through the door pillar. This seems somewhat drastic so maybe I'll continue to live with it the way it is. If there are any other suggestions out there, I'd appreciate hearing them.
KevinBN7
Member
Remember there are two catch point on the striker. One notch and one hole. When the door is fully closed the pin should be in the hole. Your striker may already be too for inward to allow the pin in the hole and it is only holding onto the notch. Use what ever means needed to be sure the pin is in the hole at fully closed position. If it is not then adjust your stiker outward. The shims spoken of in previous post do help in the fine tuning of the latch so dont discount them as a means to get this adjustment.
I hope this helps Good luck
Kevin
TimK
TimK
Thanks, Kevin. I did make sure the latch is getting to past the first catch/notch and is reaching the hole. I may fiddle some more, but will avoid surgery (thanks Nevets).
richch
The inboard/outboard adjustment can also be changed by cheating and adding flat washers between the inner door casing and the latch mounting plate inside the door. It causes the latching pin mechanism to move deeper into the door, bringing the door inboard to match the fender surface.
That has sometimes been the only way to bring all the components into perfect alignment without having to resort to carving away the striker and striker mounting holes in the alloy trim plates and door shut posts.
TimK
TimK
That's a great idea, thanks Rich.
K Door latch finish BN7 Austin Healey 2
Johnny Door handle on BN7 came loose. Austin Healey 8
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
H BN7 and BN2 Lengths Austin Healey 3
A BN7 Front Hub Stud Nuts Austin Healey 5
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
B Roof vent position on BN7 hardtop. Austin Healey 15
B Cold Start Problems BN7 Austin Healey 21
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
G 1960 3000 BN7 Top Help Austin Healey 0
F Which Original Oil filter assembly for BN7 Austin Healey 19
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
F BN7's left Austin Healey 9
F For Sale Disc Wheel Hub, From Bn7 Austin Healey Classifieds 5
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
Healey Nut BN7 Austin Healey 6
R BN7 Speedometer issues Austin Healey 1
T BN7 wiring diagram in color Austin Healey 7
F Throw away BN7 Gas tank Austin Healey 3
F For Sale BN7 gas tank, original. [I think]. Austin Healey Classifieds 0
HealeyRick Nasty BN7 Sells for $75k Austin Healey 6
busybrit Healey BN4/6 bell housing vs BN7/BT7 differences. Austin Healey 2
stretchit2 Question regarding BN7 Hardtop Austin Healey 7
rjc157 bn7 electronic choke Austin Healey 0
BN6_2197 Front Wheel Clearing of BN7 Austin Healey 35
David Townsend BN7/BT7 Limited Edition Fine Art Prints Austin Healey 6
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
J 1960 BN7 2 seater roll bar. Austin Healey 5
R BN7/BT7 Windscreen Installation Advice Austin Healey 5
Marvin Gruber BN7 on Craigslist, Nashville Austin Healey 0
J Wood dash for 60 BN7 Austin Healey 16
S Green/white BN7 Chequered Flag Austin Healey 7
R How to erect at BN7 hood [top]? Austin Healey 4
bighealeysource BN7 sells for crazy money Austin Healey 22
R Proper Timing Technique '60 BN7 Austin Healey 0
Healey Nut Red bn7 Austin Healey 7
D Original BN6 / BN7 Battery Switch Wiring Question Austin Healey 15
B BN7 with BT7 VIN on eBay Austin Healey 11
R BN7 Windscreen removal Austin Healey 7
L 3000 BN7 insulation Austin Healey 11
R BN7 Coil Wires Austin Healey 3
R Need picture [s] of a BN7 or BT7 Servo installation Austin Healey 3
M Steering Wheel modification for a BN7 Austin Healey 15
R How to install a BN7 hood [top] Austin Healey 3
R BN7 / BJ7 Dash Top Removal Austin Healey 11
AH67 The size of battery for 62 BN7 Austin Healey 16
AH67 Spinning starter motor BN7 Austin Healey 13
AH67 exhaust & Battery kill switch- mkii bn7 Austin Healey 13
dougie 1960 BN7 For Sale Austin Healey 6
Jim_Newman Bn7 fan Austin Healey 6
